node-red-contrib-meo-iot 0.1.0
A node for MEO ESP Board
npm install node-red-contrib-meo-iot
This module provices a set of nodes in Node-RED to quickly receive data from ESP8266 board with MEO ESP firmware flashed.
There are 2 nodes available at the moment:
  • An input node is to receive data from ESP Board, bellow is a sample of output format:
    "deviceId": "DEVICE_ID",
    "payload": {
      "D5": 0,
      "D6": 1,
      "D7": 1,
      "D8": 0,
      "A0": 129,
      "V1": undefined,
      "V2": undefined,
      "V3": undefined,
      "V4": undefined,
      "V5": undefined
  • An ouput node is to send configuration to target ESP Board, users can set the value from pin D0 to D5 (HIGH, LOW or PWM)
Pre-requisites
Node-RED-MEO-ESP requires Node-RED version 0.14 or more recent.
To install the stable version run the following command in your Node-RED user directory (typically ~/.node-red):
npm i node-red-contrib-meo-esp
Open your Node-RED instance and you should have one new node in input category and one new node in output category.
Version: 0.1.0
Updated 2 months, 3 weeks ago
2 in the last day
3 in the last week
15 in the last month
  • meo-esp-in
  • meo-esp-out
  • meo
  • esp
  • nodemcu
  • tobernguyen
