node-red-contrib-meo-esp 0.1.3
A node for MEO ESP Board
This module provices a set of nodes in Node-RED to quickly receive data from ESP8266 board with MEO ESP firmware flashed.
There are 2 nodes available at the moment:
- An input node is to receive data from ESP Board, bellow is a sample of output format:
"deviceId": "DEVICE_ID",
"payload": {
"D5": 0,
"D6": 1,
"D7": 1,
"D8": 0,
"A0": 129,
"V1": "VALUE FROM V1",
"V2": "VALUE FROM V2",
"V3": "VALUE FROM V3",
"V4": "VALUE FROM V4",
"V5": "VALUE FROM V5"
- An ouput node is to send configuration to target ESP Board, users can set the value from pin D0 to D5 (HIGH, LOW or PWM)
Pre-requisites
Node-RED-MEO-ESP requires Node-RED version 0.14 or more recent.
To install the stable version run the following command in your Node-RED user directory (typically ~/.node-red
npm i node-red-contrib-meo-esp
Open your Node-RED instance and you should have one new node in input category and one new node in output category.
