node-red-contrib-media-utils-plus 0.0.3
A collection of Node-RED media nodes that can be used with IBM Watson services
Node-RED media nodes using FFmpeg.
npm install node-red-contrib-media-utils
FFmpeg Conversion
Converts any audio or video format supported by FFmpeg into any supported audio format.
Supported msg.payload
types:
- String URL to audio or video
- Buffer Raw Audio Bytes
Should support any audio or video input currently supported by FFmpeg. Full list found here.
Supported output formats (audio only):
- MP3
- WAV
- FLAC
- OGG
Returns a buffer of the converted data on msg.payload
Currently been tested with:
- MP4 to MP3/WAV/FLAC/OGG
- WAV to MP3/WAV/FLAC/OGG
FFmpeg Silence Detection
Performs silence detection provided by FFmpeg on audio files.
types:
Should support any audio input currently supported by FFmpeg. Full list found here.
Returns a buffer of the audio data on msg.payload
- WAV
Defaults
- Noise tolerance: 0.008 amplitude ratio
- Duration: 0.8 seconds
Resulting silence start and end times (in seconds) will be returned as an array on msg.silences
, eg. [[0, 2], [5, 6]]
FFmpeg Segment
Splits audio files and sends a message for each segment.
Supported msg.payload types:
Returns a buffer of the split data on msg.payload
- WAV
This node splits the input into a number of segments. It splits the audio using times specified on msg.times
, eg. [5, 10]
will split the audio at 5 seconds and 10 seconds.
Each resulting segment will be sent as an individual message on msg.payload
from the node. The timesplits of each segment will be available on msg.timesplit
, eg. a timesplit of [0, 5]
started at 0 and ended at 5 seconds in the original.
Checking the "Send split messages in order with delay" checkbox will add a delay between sending each message. This delay will be equal to the previous segments length in seconds. This allows you to play the segments through a speaker in the original order for testing purposes.
Unzip
Unzips a .zip
folder into separate files.
The node requires a .zip
input file and will output the contents on the node's msg.payload
object.
.zip
file
Output types:
- A separate
buffer
for each of the files contained within the input folder.
Gotchas
Please note that currently the node returns a buffer of all the files contained in the .zip
including any dotfiles.
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright and license
Copyright 2014, 2016 IBM Corp. under the Apache 2.0 license.
