node-red-contrib-maxcube 0.0.4
A node-red node to control the eQ-3 Max! Cube
npm install node-red-contrib-maxcube
A collection of node-red nodes to control the eQ-3 Max! Cube
cd $HOME/.node-red
Restart Node-RED.
maxcube config node
Set ip and port of your Max! Cube
maxcube (input)
A node to query the eQ-3 Max! Cube for device states.
Whenever an input message is received, device states are updated from the Max! Cube, and sent as separate messages (one for each device) with following structure:
  "rf_address": "0abc12",
  "initialized": true,
  "fromCmd": false,
  "error": false,
  "valid": true,
  "mode": "MANUAL",
  "dst_active": true,
  "gateway_known": true,
  "panel_locked": false,
  "link_error": false,
  "battery_low": false,
  "valve": 0,
  "setpoint": 5,
  "temp": 15.4
maxcube (output)
A node to set the temperature of a device.
Accepts messages with payload of type object with following structure:
  "degrees": 20
Version: 0.0.4
Updated 7 years, 8 months ago
7 in the last week
  • maxcube in
  • maxcube out
  • maxcube-server
  • Max Cube
