node-red-contrib-matrixbot 0.0.2
Matrix bot nodes for Node-RED
npm install node-red-contrib-matrixbot
This package contains nodes to send and receive messages as a Matrix node.
Quick usage guide
This package adds 3 node types to Node-RED palette (Matrix section, at the bottom):
  • Matrix sender: sends messages from your Node-RED flow to the chatroom
  • Matrix receiver: listens to messages in a chatroom and sends them to your Node-RED flow
  • Matrix command: listens only to messages starting with a specific command and sends them to your Node-RED flow
All of these nodes require a Matrix Configuration with the following settings:
  • User ID: the user ID in the matrix server, for instance @mybot:matrix.org
  • Access token: the access token of the user in the matrix server
  • Server URL: URL of the Matrix homeserver, e.g. https://matrix.org
  • Room ID: ID of the chatroom to join when starting. If no room is specified, it will automatically join any room where it is invited
Install guide
Make sure you have Docker installed, run:
git clone https://github.com/mlopezr/node-red-contrib-matrixbot.git
cd node-red-contrib-matrixbot
npm install
docker run --rm -it -p 1880:1880 --name mynodered -v `pwd`:/data/nodes nodered/node-red-docker
Then open http://127.0.0.1:1880/ in a browser.
Version: 0.0.2
Updated 5 months, 1 week ago
4 in the last day
10 in the last week
28 in the last month
  • matrix bot
  • matrix sender
  • matrix receiver
  • matrix command
  • matrix
  • bot
  • mlopezr
