node-red-contrib-mail-parse 0.1.5
Node-RED node to parse mime encoded e-mail messages.
Node-Red node to parse mime encoded e-mail messages using mailparser.
This node parses raw source of e-mail messages in mime format into a structured object. This allows you to get access the e-mail properties and do something with it in your flows.
#Install
npm install node-red-contrib-mail-parse
Common mail properties
Property | Method | Example |
to | msg.payload.to | [ { "address": "receiver@example.com", "name": "Receiver" } ] |
from | msg.payload.from | [ { "address": "sender@example.com", "name": "Sender" } ] |
subject | msg.payload.subject | Hello world! |
body (html) | msg.payload.html | How are you today? |
body (text) | msg.payload.text | How are you today? |
attachments | msg.payload.attachments[] | *** see attachments object properties *** |
number of attachments | msg.payload.attachments.length | 4 |
All mail properties
- headers - unprocessed headers in the form of -
{key: value}
- if there were multiple fields with the same key then the value is an array - from - an array of parsed
From
addresses -[{address:'[email protected]',name:'Sender Name'}]
(should be only one though) - to - an array of parsed
To
addresses - cc - an array of parsed
Cc
addresses - bcc - an array of parsed 'Bcc' addresses
- subject - the subject line
- references - an array of reference message id values (not set if no reference values present)
- inReplyTo - an array of In-Reply-To message id values (not set if no in-reply-to values present)
- priority - priority of the e-mail, always one of the following: normal (default), high, low
- text - text body
- html - html body
- date - date field as a
Date()
object. If date could not be resolved or is not found this field is not set. Check the original date string fromheaders.date
- attachments - an array of attachments
Attachments properties
attachments = [{
contentType: 'image/png',
fileName: 'image.png',
contentDisposition: 'attachment',
contentId: '5.1321281380971@localhost',
transferEncoding: 'base64',
length: 126,
generatedFileName: 'image.png',
checksum: 'e4cef4c6e26037bcf8166905207ea09b',
content: <Buffer ...>
#Nodes
[{"id":"70c00d9b.468a74","type":"debug","z":"2f3fbadc.6f0ae6","name":"to","active":false,"console":"false","complete":"payload.to","x":1050,"y":220,"wires":[]},{"id":"512a5203.adf10c","type":"mail-parse","z":"2f3fbadc.6f0ae6","name":"parse e-mail","x":750,"y":280,"wires":[["70c00d9b.468a74","ce8c0850.ed61a8","5658ba55.84f894","b0ed1a09.d7f9c8","c426369.c4b22c8","e14f2c24.15207"],["c390bdb2.61465","9a055e4d.67efe"]]},{"id":"8aeef9ea.674938","type":"file in","z":"2f3fbadc.6f0ae6","name":"from file \"email.eml\"","filename":"email1.eml","format":"utf8","x":500,"y":280,"wires":[["512a5203.adf10c"]]},{"id":"c6f05592.f86158","type":"inject","z":"2f3fbadc.6f0ae6","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":250,"y":280,"wires":[["8aeef9ea.674938"]]},{"id":"ce8c0850.ed61a8","type":"debug","z":"2f3fbadc.6f0ae6","name":"from","active":false,"console":"false","complete":"payload.from","x":1050,"y":180,"wires":[]},{"id":"5658ba55.84f894","type":"debug","z":"2f3fbadc.6f0ae6","name":"subject","active":false,"console":"false","complete":"payload.subject","x":1060,"y":260,"wires":[]},{"id":"b0ed1a09.d7f9c8","type":"debug","z":"2f3fbadc.6f0ae6","name":"attachments count","active":false,"console":"false","complete":"payload.attachments","x":1090,"y":380,"wires":[]},{"id":"e14f2c24.15207","type":"debug","z":"2f3fbadc.6f0ae6","name":"body (html)","active":false,"console":"false","complete":"payload.html","x":1070,"y":300,"wires":[]},{"id":"c426369.c4b22c8","type":"debug","z":"2f3fbadc.6f0ae6","name":"body (text)","active":false,"console":"false","complete":"payload.text","x":1070,"y":340,"wires":[]},{"id":"c390bdb2.61465","type":"debug","z":"2f3fbadc.6f0ae6","name":"attachments","active":true,"console":"false","complete":"payload","x":1070,"y":460,"wires":[]}]
[{"id":"70c00d9b.468a74","type":"debug","z":"2f3fbadc.6f0ae6","name":"to","active":false,"console":"false","complete":"payload.to","x":1050,"y":220,"wires":[]},{"id":"512a5203.adf10c","type":"mail-parse","z":"2f3fbadc.6f0ae6","name":"parse e-mail","x":750,"y":280,"wires":[["70c00d9b.468a74","ce8c0850.ed61a8","5658ba55.84f894","b0ed1a09.d7f9c8","c426369.c4b22c8","e14f2c24.15207"],["c390bdb2.61465","9a055e4d.67efe"]]},{"id":"8aeef9ea.674938","type":"file in","z":"2f3fbadc.6f0ae6","name":"from file \"email.eml\"","filename":"email1.eml","format":"utf8","x":500,"y":280,"wires":[["512a5203.adf10c"]]},{"id":"c6f05592.f86158","type":"inject","z":"2f3fbadc.6f0ae6","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":250,"y":280,"wires":[["8aeef9ea.674938"]]},{"id":"ce8c0850.ed61a8","type":"debug","z":"2f3fbadc.6f0ae6","name":"from","active":false,"console":"false","complete":"payload.from","x":1050,"y":180,"wires":[]},{"id":"5658ba55.84f894","type":"debug","z":"2f3fbadc.6f0ae6","name":"subject","active":false,"console":"false","complete":"payload.subject","x":1060,"y":260,"wires":[]},{"id":"b0ed1a09.d7f9c8","type":"debug","z":"2f3fbadc.6f0ae6","name":"attachments count","active":false,"console":"false","complete":"payload.attachments","x":1090,"y":380,"wires":[]},{"id":"e14f2c24.15207","type":"debug","z":"2f3fbadc.6f0ae6","name":"body (html)","active":false,"console":"false","complete":"payload.html","x":1070,"y":300,"wires":[]},{"id":"c426369.c4b22c8","type":"debug","z":"2f3fbadc.6f0ae6","name":"body (text)","active":false,"console":"false","complete":"payload.text","x":1070,"y":340,"wires":[]},{"id":"c390bdb2.61465","type":"debug","z":"2f3fbadc.6f0ae6","name":"attachments","active":false,"console":"false","complete":"payload","x":1070,"y":460,"wires":[]},{"id":"9a055e4d.67efe","type":"xml-validate","z":"2f3fbadc.6f0ae6","name":"validate xsd schema","filename":"people.xsd","x":1100,"y":540,"wires":[["4ccfe452.85a07c"],["8c78b921.1c43f8"],["1a0e3fcd.ea861"]]},{"id":"4ccfe452.85a07c","type":"debug","z":"2f3fbadc.6f0ae6","name":"xml is valid !","active":false,"console":"false","complete":"fileName","x":1350,"y":500,"wires":[]},{"id":"8c78b921.1c43f8","type":"debug","z":"2f3fbadc.6f0ae6","name":"xml is invalid","active":false,"console":"false","complete":"fileName","x":1350,"y":560,"wires":[]},{"id":"1a0e3fcd.ea861","type":"debug","z":"2f3fbadc.6f0ae6","name":"show validation errors","active":true,"console":"false","complete":"payload","x":1380,"y":620,"wires":[]}]
#Author
