node-red-contrib-luxtronik 1.0.4
Make node-red read data from a Luxtronik heatpump controller
npm install node-red-contrib-luxtronik
Node-Red (http://nodered.org) node for communicating with a Luxtronik heatpump controller.
#Install
Run the following command after you have done a global install of Node-RED
sudo npm install -g node-red-contrib-luxtronik
#Usage
The luxtronik node will appear in the "IoT" catagory on the Node-Red pallet. Drag and drop it onto the canvas and configure as you would any other node-red module.
The luxtronik node allows you to set the IP-Address and Port of you heatpump controller.
Warning: Do not expose the ethernet connection of your luxtronik to the internet. The Linux system is not being updated by Alpha-Innotec and the root account has a default password.
#Disclaimer
Use this node at your own risk.
Author
Christian Brandlehner, https://github.com/cbrandlehner
#More Info on Luxtronik
A more powerful tool and background info on the API can be found at https://sourceforge.net/projects/opendta/
Version: 1.0.4
Updated 8 years, 1 month ago
3 in the last week
  • luxtronik
  • luxtronik
