node-red-contrib-lazurite 0.0.49
R/W data of Lazurite-Gateway.
#node-red-contrib-lazurite
#Install
Run the following command: npm install node-red-contrib-lazurite
##requirement: hardware: Raspberry Pi + Lazurite Pi Gateway Software: LazDriver (Kernel driver) liblazurite (linux .so) also node-red
install and setup
0. install required modules (if not installed)
git clone git://github.com/LAPIS-Lazurite/LazuriteInstaller cd LazuriteInstaller ./install.sh
1. install node-red-lazurite
Execute following command. npm install node-red-lazurite
then the node may be installed in "/home/pi/node_modules".
2. enabling node
edit "~/.node-red/setup.js" modify parameter of nodesDir to enable "/home/pi/node_modules"
if there is not "~/.node-red/setup.js", start node-red. Then the file will be created.
How to use
start and stop node-red
start node-red: select "node-red" in menu bar. or input "node-red-start" on console. stop node-red: input "node-red-stop" on console.
When node is installed successfully, the nodes named "lazurite rx" and "lazurite tx" are appeared. Please put the node and click it for detailes of parameters and usages.
