node-red-contrib-later 0.0.5
A node red node for triggering using later.js
npm install node-red-contrib-later
A node red node for triggering using later.js.
$npm install node-red-contrib-later
This node accepts a msg and sends it on according to a schedule defined by a string parsed through later.parse.text(). In all cases the schedule string in the node schedule string property is used if set.
If the schedule fails to parse node.warn() is called with details of the string and error as reported by the parser, and the msg.payload is sent on immediately.
If the schedule is empty, the msg.payload is passed straight through.
To cancel a running schedule pass in a message with an empty payload with the msg.later property from a previously sent sceduled message.
Payload as an object
If the payload is an object the property msg.payload.later is used as the schedule string if the node doesn't have a schedule property set.
Examples
See the documentation of later.parse.text() for the format of the schedule string.
every 10 seconds or at 10:15 am are simple examples.
Example flow files
Try pasting in the flow file below that sends the message every 10th second twice.
[{"id":"b9995d6c.4666a","type":"later","name":"The schedule","schedule":"every 10 seconds","x":384,"y":129,"z":"80e3898c.7f1c78","wires":[["b8f9cfce.47063","4a71efdd.b58e1"]]},{"id":"b9335ee3.46cca","type":"inject","name":"","topic":"","payload":"comes out later","payloadType":"string","repeat":"","crontab":"","once":true,"x":124,"y":130,"z":"80e3898c.7f1c78","wires":[["b9995d6c.4666a"]]},{"id":"b8f9cfce.47063","type":"debug","name":"","active":true,"console":"false","complete":"true","x":620,"y":129,"z":"80e3898c.7f1c78","wires":[]},{"id":"4a71efdd.b58e1","type":"function","name":"Run schedule 2 times","func":"if (msg.later.count >= 2) {\n    delete msg.payload; \n    return msg;\n} else {\n    return;\n}\n","outputs":1,"valid":true,"x":382,"y":248,"z":"80e3898c.7f1c78","wires":[["b9995d6c.4666a"]]}]
This flow does essentially the same, but uses a schedule sent in as a property in msg.payload as an object.
[{"id":"e28ebddd.1d714","type":"inject","name":"","topic":"","payload":"{\"later\":\"every 10 sec\"}","payloadType":"string","repeat":"","crontab":"","once":true,"x":115,"y":196,"z":"cb2e612f.34d1a","wires":[["64e96677.9b1698"]]},{"id":"64e96677.9b1698","type":"json","name":"","x":262,"y":196,"z":"cb2e612f.34d1a","wires":[["507261e9.af8da"]]},{"id":"507261e9.af8da","type":"later","name":"","schedule":"","x":436,"y":196,"z":"cb2e612f.34d1a","wires":[["d8bf725e.27409","db2fa266.24d06"]]},{"id":"d8bf725e.27409","type":"debug","name":"","active":true,"console":"false","complete":"false","x":593,"y":196,"z":"cb2e612f.34d1a","wires":[]},{"id":"db2fa266.24d06","type":"function","name":"Run schedule 2 times","func":"if (msg.later.count >= 2) {\n    delete msg.payload; \n    return msg;\n} else {\n    return;\n}\n","outputs":1,"valid":true,"x":442,"y":304,"z":"cb2e612f.34d1a","wires":[["507261e9.af8da"]]}]
Author
  • Dean Sellers
The MIT License (MIT)
Copyright (c) 2015 Lighthouse Automation <dean@lighthouseautomation.com.au>
Version: 0.0.5
Updated 7 years, 9 months ago
7 in the last week
  • later
