node-red-contrib-keypress 1.0.1
A Node-RED node capturing keypress input in terminal
npm install node-red-contrib-keypress
npm i node-red-contrib-keypress
Or install it globally
sudo npm i -g node-red-contrib-keypress
Sample node messages
	key: "up"
	key: "a"
Keys mapping
Keypress Node supports following sample keys mapping:
up, down, left, right, space, backspace, return, escape, a, b, c, d, ..., 1, 2, 3, ...
If you do not specify input key, all keys will be captured. Insert debug node to see all captured keys mappings.
Shift & ctrl capturing is currently not supported due to inconsistencies in different terminals (TODO).
Note: Keypress capturing works only when terminal window where you started node-red is in the front. If your terminal does not support ttty, you will see keys output in terminal.
Example
Simple flow to capture keyboard arrows input
[{"id":"f9172ee0.b0107","type":"keypress","z":"1bc8013.5b95eff","key":"","x":120,"y":140,"wires":[["800f4214.80701"]]}]
Version: 1.0.1
Updated 11 years, 5 months ago
Rating: 1.0 1
50 in the last week
  • keypress
  • keypress
