node-red-contrib-keeper 0.0.5
Node-RED nodes to save and retrieve document from Nunux Keeper
npm install node-red-contrib-keeper
Node-RED node to save and retrieve document from Nunux Keeper v2.
Please note that this node is not compatible with Nunux Keeper v1.
Screenshot
npm install node-red-node-keeper
Request node
Create, update, delete or retrieve a document from Nunux Keeper v2.
The document on Keeper is taken from the node docid property or the msg.docid property.
The document content is sent as msg.payload property. If the request fails msg.error will contain an error object.
To create a document The message payload should be as follow:
  • title: Document title
  • label: Label to classify the document (The label ID)
  • content: Document content
  • contentType: Document type
  • origin: Document origin URL
All attributes are optional. If only origin attribute is provided, then the document will be extracted from the endpoint.
Version: 0.0.5
Updated 7 years, 11 months ago
3 in the last week
  • keeper-credentials
  • keeper
  • nunux-keeper
  • nunux
  • keeper
