node-red-contrib-jwt 0.1.0
JWT Validator and Signer
npm install node-red-contrib-jwt
Node-red node for sign and validate JWT tokens.
Functions
  • Sign msg.payload, msg.topic or msg.token using HS* or RS* algorithms.
  • Validate msg.payload, msg.topic, msg.token, req.headers.authorization or access_token var using HS* or RS* algorithms.
Roadmap
  • Handle certs better;
  • Validations;
  • Better UI.
Sample/Demo Flows
PEM Key File
This flow starts with injecting an RSA Private Key and Public Key each to a file (within node-red).
The Sign and Validate node will trigger a JWT claim to be signed using the Private key above (debugging the signed token), and then validating it with the matching Public key (debugging the validated JWT payload)
PEM Key File Example
Flow JSON:
[{"id":"5a455541.3fdcac","type":"tab","label":"PEM Key","disabled":false,"info":""},{"id":"254d3459.0f6a6c","type":"inject","z":"5a455541.3fdcac","name":"Sign and Validate","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":159,"y":213,"wires":[["b41b1ce9.4af46"]]},{"id":"952eeded.4e3b8","type":"jwt sign","z":"5a455541.3fdcac","name":"","alg":"RS512","exp":"3601","jwkurl":"","jwkkid":"rsa_priv_key","secret":"","key":"rsa_priv_key","signvar":"payload","storetoken":"payload","x":558,"y":212,"wires":[["923d5346.7095a","d6f89849.4d8f88"]]},{"id":"923d5346.7095a","type":"debug","z":"5a455541.3fdcac","name":"Debug Signed JWT","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":780,"y":212,"wires":[]},{"id":"d6f89849.4d8f88","type":"jwt verify","z":"5a455541.3fdcac","name":"","alg":["RS512"],"jwkurl":"","secret":"","key":"rsa_pub_key","signvar":"payload","storetoken":"payload","x":554,"y":318,"wires":[["c4e176.85833e88"]]},{"id":"c4e176.85833e88","type":"debug","z":"5a455541.3fdcac","name":"Debug Validated JWT","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":784,"y":318,"wires":[]},{"id":"b41b1ce9.4af46","type":"template","z":"5a455541.3fdcac","name":"Create Claims","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"sub\":\"user\",\"iss\":\"http://nodered.nulli.com:1880/oauth2\",\"tokenName\":\"id_token\",\"aud\":\"client\",\"azp\":\"client\",\"tokenType\":\"JWTToken\"}","output":"json","x":352,"y":213,"wires":[["952eeded.4e3b8"]]},{"id":"4bda0708.c98b08","type":"file","z":"5a455541.3fdcac","name":"","filename":"rsa_priv_key","appendNewline":false,"createDir":false,"overwriteFile":"true","x":707,"y":82,"wires":[]},{"id":"27b80fdd.cf946","type":"inject","z":"5a455541.3fdcac","name":"","topic":"Create Key Files","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":166,"y":84,"wires":[["394036c2.6c15ea","48b5f522.c8aa7c"]]},{"id":"394036c2.6c15ea","type":"template","z":"5a455541.3fdcac","name":"RSA Private Key","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"-----BEGIN RSA PRIVATE KEY-----\nMIIEpAIBAAKCAQEA2+d7uinqCDZYnZpyqCGnoeAR+aCWDC0YI7ZqKzH2RyjcHOpI\nIoswrPRZgF56y1x87a/QatPZmNmctEeNSNOM1qHfZSyxHCEyqENiNS3PEzUJ9RHK\nB7eDHKZGeQYhOmtXqm3zB8ORtVrngvDBsZT9A686p7Zo21ESOlXFZBieRVyimrEe\nJqcSwKq4gYG8GU7lc7r1fZCi81KL5K/6dxdMrmQeMYXgetH5SPIBFo4Mq47oJqiV\n48T87zCFHEzEikC+f1bbsNmOfryAwZtzTHQ7i/AU6kpOiNRMizC/cP7SNodc01Mk\nE1IXAv4fXTvEcmxTyRWPp2kiPR5oZ1R76B6v3wIDAQABAoIBAG1etQ/DFu3csbg4\n/7uVeX0uJ2KDNv15VB8285jmMXn03XzYHOZpWd07bmRFGUeZiVzh64OmN/wohyK2\nz5Mf/FUnjycP0kqOTFaZpPeUAACqiXhEz7mE0QXnwPciUFZw2tod8xiycP7E5o4e\nVgePdUNm3IJbW81wheNTk2gUQmt2Giwiu8ilcvPXyvNKBRLw+XM7UXINYtBk/7xM\ntcYd19mmjumUUXK4cw4qhoNE3l+GfCJ8S+FjCazLFCFnAe2CKX3CeJv7paoxenit\niQ6lQk1nhdN4+T5CnrTao1P9nBZiBqtvOICRDc+9QgMKHmmuPzPeYuqmGPd6F8s7\nMIQ4xvECgYEA8lxCg5sH4MUZbNFSn3fkP/iisiRzth4TXHv9OmdcRdTRSJrWXxND\nWbTb+Alj5vP4mBgxMTcycPS/qLSInQJaXjxEF4aQlBNLj4iZRvZENkseKrju+MyO\nJGOmcnkzfFiZLb/TLFMhBBpfVPItZci1kBE8/Mz6b9S1PmZnBWjdJfkCgYEA6Eex\nTtySIyLq/VQcuw+fgCI0lkZ0Ctg/nbs1YHbfMcyih60bWRsDX9KvexWy60nUQHNu\n/pc73rSW8ggIfTqx2UTHJTiNwBLm/XE2HxPnzcB6zf9CBhgqoQPxgBWfxtaiGCGR\nMyrsNxXt49LMUn2p6JNuLXtaKWweDfJbziLiGpcCgYEAkQFIPouENCRZKPU4lPbb\nlrbBSQpsPNtTxDLe+JGc8J77NJCHkEzrMAH41jdwEV+JLh7TV9npkRGullaloiMl\nRFqUdurpF99Phyo4Yu+3MjDRdMg/GpbwuK7yiG0hs9UimO+7fjqid1z8Csv3A34J\nu4/EyJAvirdeVV5ZZzAtmKkCgYEAmzIrmdFuIuPVtmVYvPN3UpmIIU/5gLVz6+OF\nimpiPlfH0Hcs6qBN5NxUOx0IaoTtuBJoetp5OhfXMueDJIjvA4gctxXOQCNhCr11\nt9YI70RHyRNf/cpv0R1dYoMQOj52F0F2ToXDRhr001+o/QTRXYAEAYeFel+uxQrF\npDlScQkCgYA7JewsTmXZyCfUytL9r+SxNjZLicmw2JALGBwavY5rZtSFKsmPr/zV\nDwjP9gtV6T/ObEshwDonI0tsDq6KOJB/8AI97uwcPa1c8x0jnfvRe9uoZ/qiKA+X\nqwqVkk/b6KowQo/XFMFa05batx2Xs41m5pQ/sSQPuR0FWHFVmKTF8g==\n-----END RSA PRIVATE KEY-----\n","output":"str","x":480,"y":83,"wires":[["4bda0708.c98b08"]]},{"id":"fd70bdee.e7ebd","type":"file","z":"5a455541.3fdcac","name":"","filename":"rsa_pub_key","appendNewline":false,"createDir":false,"overwriteFile":"true","x":706,"y":131,"wires":[]},{"id":"48b5f522.c8aa7c","type":"template","z":"5a455541.3fdcac","name":"RSA Public Key","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"-----BEGIN PUBLIC KEY-----\nMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEA2+d7uinqCDZYnZpyqCGn\noeAR+aCWDC0YI7ZqKzH2RyjcHOpIIoswrPRZgF56y1x87a/QatPZmNmctEeNSNOM\n1qHfZSyxHCEyqENiNS3PEzUJ9RHKB7eDHKZGeQYhOmtXqm3zB8ORtVrngvDBsZT9\nA686p7Zo21ESOlXFZBieRVyimrEeJqcSwKq4gYG8GU7lc7r1fZCi81KL5K/6dxdM\nrmQeMYXgetH5SPIBFo4Mq47oJqiV48T87zCFHEzEikC+f1bbsNmOfryAwZtzTHQ7\ni/AU6kpOiNRMizC/cP7SNodc01MkE1IXAv4fXTvEcmxTyRWPp2kiPR5oZ1R76B6v\n3wIDAQAB\n-----END PUBLIC KEY-----\n","output":"str","x":479,"y":132,"wires":[["fd70bdee.e7ebd"]]}]
JWK URL Keyset
The Sign and Validate node will trigger a JWT claim to be signed using an Private EC Key retrieved from a URL hosted by node-red (debugging the signed token), and then validating it with the matching Public EC key (debugging the validated JWT payload)
JWK URL Keyset Example
Flow JSON:
[{"id":"2bb941b5.7b5d9e","type":"tab","label":"Test JWT","disabled":false,"info":""},{"id":"920519b5.2b6e38","type":"inject","z":"2bb941b5.7b5d9e","name":"Sign and Validate","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":147.5,"y":214,"wires":[["60e22738.f40298"]]},{"id":"5138b19b.cd216","type":"jwt sign","z":"2bb941b5.7b5d9e","name":"","alg":"ES512","exp":"3601","jwkurl":"http://localhost:1880/priv_jwk","jwkkid":"nulli-ec-512","secret":"","key":"","signvar":"payload","storetoken":"payload","x":552.5,"y":213,"wires":[["6e7758b9.2b6f68","f900de63.1632b"]]},{"id":"6e7758b9.2b6f68","type":"debug","z":"2bb941b5.7b5d9e","name":"Debug Signed JWT","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":774.5,"y":213,"wires":[]},{"id":"f900de63.1632b","type":"jwt verify","z":"2bb941b5.7b5d9e","name":"","alg":["ES512"],"jwkurl":"http://localhost:1880/pub_jwk","secret":"","key":"","signvar":"payload","storetoken":"payload","x":548.5,"y":319,"wires":[["f05412ad.d780a"]]},{"id":"f05412ad.d780a","type":"debug","z":"2bb941b5.7b5d9e","name":"Debug Validated JWT","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":778.5,"y":319,"wires":[]},{"id":"4ba13e9e.f47c9","type":"template","z":"2bb941b5.7b5d9e","name":"Private JWK","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n  \"keys\": [\n    {\n      \"kty\": \"EC\",\n      \"d\": \"AXLoWyI1nApmP8lD1iFo3qjwBjJluXwNdYizbrcXpgUoX6F0gTtsOEQD9AxTqElgwHDfbs_IcwOSjfCh_4QeJnUM\",\n      \"use\": \"sig\",\n      \"crv\": \"P-521\",\n      \"kid\": \"nulli-ec-512\",\n      \"x\": \"AD0pM1Vkdw12HeM5AeY6PMuMbc66uG8oRiKV9hnm2x8U_dLgA7gRYNim4Y8_rixOeoHYlMzarRtDThLBS4CBlgrG\",\n      \"y\": \"ABuSEiwuSTIy02f1G2OnuSQN-9-s4KJxxXSqgMonKv3CPWaBVTJqfB4Viz9xUoY16d6ngJ2o66Kp2FUetTmxSptq\",\n      \"alg\": \"ES512\"\n    }\n  ]\n}","output":"json","x":339.5,"y":40,"wires":[["20446d4f.225862"]]},{"id":"20446d4f.225862","type":"http response","z":"2bb941b5.7b5d9e","name":"","statusCode":"200","headers":{},"x":535.5,"y":40,"wires":[]},{"id":"5790c71a.0ca028","type":"http in","z":"2bb941b5.7b5d9e","name":"","url":"/priv_jwk","method":"get","upload":false,"swaggerDoc":"","x":143.5,"y":41,"wires":[["4ba13e9e.f47c9"]]},{"id":"60e22738.f40298","type":"template","z":"2bb941b5.7b5d9e","name":"Create Claims","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"sub\":\"user\",\"iss\":\"http://nodered.nulli.com:1880/oauth2\",\"tokenName\":\"id_token\",\"aud\":\"client\",\"azp\":\"client\",\"tokenType\":\"JWTToken\"}","output":"json","x":346.5,"y":214,"wires":[["5138b19b.cd216"]]},{"id":"640d2eb5.4dec3","type":"template","z":"2bb941b5.7b5d9e","name":"Public JWK","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n  \"keys\": [\n    {\n      \"kty\": \"EC\",\n      \"use\": \"sig\",\n      \"crv\": \"P-521\",\n      \"kid\": \"nulli-ec-512\",\n      \"x\": \"AD0pM1Vkdw12HeM5AeY6PMuMbc66uG8oRiKV9hnm2x8U_dLgA7gRYNim4Y8_rixOeoHYlMzarRtDThLBS4CBlgrG\",\n      \"y\": \"ABuSEiwuSTIy02f1G2OnuSQN-9-s4KJxxXSqgMonKv3CPWaBVTJqfB4Viz9xUoY16d6ngJ2o66Kp2FUetTmxSptq\",\n      \"alg\": \"ES512\"\n    }\n  ]\n}","output":"json","x":342,"y":130,"wires":[["a03b5868.ec3528"]]},{"id":"a03b5868.ec3528","type":"http response","z":"2bb941b5.7b5d9e","name":"","statusCode":"200","headers":{},"x":538,"y":130,"wires":[]},{"id":"e53cbf9a.80f7f","type":"http in","z":"2bb941b5.7b5d9e","name":"","url":"/pub_jwk","method":"get","upload":false,"swaggerDoc":"","x":146,"y":131,"wires":[["640d2eb5.4dec3"]]}]
Useful sites:
Version: 0.1.0
Rating: 4.7 3
127 in the last week
  • jwt sign
  • jwt verify
  • jwt
  • node
