node-red-contrib-json2csv 0.0.3
A node to convert json to csv
npm install node-red-contrib-json2csv
Node-RED wrapper to the jsonexport npm module. This allows for conversion of a json input into a csv file, without needing to specify the column headers. The headers are populated automatically, making this node simple to use for JSON data that is generated by apps or read from databases.
Input
Set msg.payload to a json stream buffer. The file inject from node-red-contrib-browser-utils works well as input to this node.
Output
msg.payload will be a csv string.
Contributing
For simple typos and fixes please just raise an issue pointing out our mistakes. If you need to raise a pull request please read our contribution guidelines before doing so.
Copyright 2017 IBM Corp. under the Apache 2.0 license.
Version: 0.0.3
133 in the last week
  • json-2-csv
  • json
  • csv
  • Soheel Chughtai
