node-red-contrib-ipc 0.0.2
Generate messages when data is sent to node-RED using inter-process communication
npm install node-red-contrib-ipc
A Node-RED node for receiving Inter-Process Communication messages using UNIX-domain sockets where available, and using Named Pipes on Windows
Run the install command in Node-RED installation directory
The node may also be installed globally using the -g switch. There are no external dependencies.
The node creates a server at the specified Path. This may be anywhere in the filesystem for UNIX-like operating systems (provided the node-RED process has adequate file permissons), or on Windows a Named Pipe psuedo-file, e.g. \\.\Pipe\test-1. The Path must not exist when the flow is deployed. The node attempts to clean up after itself when node-RED exits or the flow is redployed, releasing the Path for re-use.
Processes may connect to this Path and should send text data (in UTF-8 encoding). Each line of text will generate an output message, where the message Payload is the received text line (minus any line terminating characters), and the message Topic is set by the node. The line ending characters are \n on UNIX-like operating systems, and \r\n on Windows.
On Unix-like operating systems, the netcat-BSD tool can be used to send output from a shell script to a UNIX-domain socket at the specified Path, for example:
ls | nc -U /Users/max/tst.socket
Example node.js code to send text to a Windows Named Pipe is provided in the Windows directory.
Example Node-RED flow:
[{"id":"36333a8e.c9ccc6","type":"IPC-in","z":"6e8b42ee.9174bc","path":"/Users/max/tst.socket","topic":"Test/data",
"name":"","x":126,"y":265,"wires":[["64063cc4.9bf9c4"]]}]
Version: 0.0.2
Updated 8 years, 9 months ago
License: BSD-2-Clause
2 in the last week
  • IPC-in
  • ipc
  • socket
  • pipe
