node-red-contrib-iot-virtual-device 0.1.3
A set of nodes to help you create simulated IoT devices connected to IBM Watson IoT Platform.
npm install node-red-contrib-iot-virtual-device
This module provides a set of nodes in Node-RED to rapidly implement simulated IoT device behavior and use it to run many device instances.
Read here how to deploy a sample application to IBM Bluemix
Run the following command in your Node-RED user directory (typically ~/.node-red
- **_Device Schema_** (configuration node) to define the device type
- **_Start Device_** to create a new instance of a device type
- **_Generate Event_** to send events to the IoT platform
- **_Set Properties_** to set properties of a device instance
- **_Device Function_** to write customized behavior using a specific device instance properties
- **_Device Listener_** to react on changes in device instances state (e.g. property change)
