node-red-contrib-internetattv 0.1.6
Node-RED node for communication with Internet@TV Samsung Televisions.
msg should contain ip and command if not defined in node configuration. msg properies overwrite configuration of node properties.
Example: var msg = { ip: "192.168.1.150", command: "AV1" };
Commands
- 0
- 1
- 11
- 12
- 16_9
- 2
- 3
- 3SPEED
- 4
- 4_3
- 5
- 6
- 7
- 8
- 9
- AD
- ADDDEL
- ALT_MHP
- ANGLE
- ANTENA
- ANYNET
- ANYVIEW
- APP_LIST
- ASPECT
- AUTO_ARC_ANTENNA_AIR
- AUTO_ARC_ANTENNA_CABLE
- AUTO_ARC_ANTENNA_SATELLITE
- AUTO_ARC_ANYNET_AUTO_START
- AUTO_ARC_ANYNET_MODE_OK
- AUTO_ARC_AUTOCOLOR_FAIL
- AUTO_ARC_AUTOCOLOR_SUCCESS
- AUTO_ARC_C_FORCE_AGING
- AUTO_ARC_CAPTION_ENG
- AUTO_ARC_CAPTION_KOR
- AUTO_ARC_CAPTION_OFF
- AUTO_ARC_CAPTION_ON
- AUTO_ARC_JACK_IDENT
- AUTO_ARC_LNA_OFF
- AUTO_ARC_LNA_ON
- AUTO_ARC_PIP_CH_CHANGE
- AUTO_ARC_PIP_DOUBLE
- AUTO_ARC_PIP_LARGE
- AUTO_ARC_PIP_LEFT_BOTTOM
- AUTO_ARC_PIP_LEFT_TOP
- AUTO_ARC_PIP_RIGHT_BOTTOM
- AUTO_ARC_PIP_RIGHT_TOP
- AUTO_ARC_PIP_SMALL
- AUTO_ARC_PIP_SOURCE_CHANGE
- AUTO_ARC_PIP_WIDE
- AUTO_ARC_RESET
- AUTO_ARC_USBJACK_INSPECT
- AUTO_FORMAT
- AUTO_PROGRAM
- AV1
- AV2
- AV3
- BACK_MHP
- BOOKMARK
- CALLER_ID
- CAPTION
- CATV_MODE
- CH_LIST
- CHDOWN
- CHUP
- CLEAR
- CLOCK_DISPLAY
- COMPONENT1
- COMPONENT2
- CONTENTS
- CONVERGENCE
- CONVERT_AUDIO_MAINSUB
- CUSTOM
- CYAN
- DEVICE_CONNECT
- DISC_MENU
- DMA
- DNET
- DNIe
- DNSe
- DOOR
- DOWN
- DSS_MODE
- DTV
- DTV_LINK
- DTV_SIGNAL
- DVD_MODE
- DVI
- DVR
- DVR_MENU
- DYNAMIC
- ENTERTAINMENT
- ESAVING
- EXT1
- EXT10
- EXT11
- EXT12
- EXT13
- EXT14
- EXT15
- EXT16
- EXT17
- EXT18
- EXT19
- EXT2
- EXT20
- EXT21
- EXT22
- EXT23
- EXT24
- EXT25
- EXT26
- EXT27
- EXT28
- EXT29
- EXT3
- EXT30
- EXT31
- EXT32
- EXT33
- EXT34
- EXT35
- EXT36
- EXT37
- EXT38
- EXT39
- EXT4
- EXT40
- EXT41
- EXT5
- EXT6
- EXT7
- EXT8
- EXT9
- FACTORY
- FAVCH
- FF
- FF_
- FM_RADIO
- GAME
- GREEN
- GUIDE
- HDMI
- HDMI1
- HDMI2
- HDMI3
- HDMI4
- HELP
- HOME
- ID_INPUT
- ID_SETUP
- INFO
- INSTANT_REPLAY
- LEFT
- LINK
- LIVE
- MAGIC_BRIGHT
- MAGIC_CHANNEL
- MDC
- MENU
- MIC
- MORE
- MOVIE1
- MS
- MTS
- MUTE
- NINE_SEPERATE
- OPEN
- PANNEL_CHDOWN
- PANNEL_CHUP
- PANNEL_ENTER
- PANNEL_MENU
- PANNEL_POWER
- PANNEL_SOURCE
- PANNEL_VOLDOW
- PANNEL_VOLUP
- PANORAMA
- PAUSE
- PCMODE
- PERPECT_FOCUS
- PICTURE_SIZE
- PIP_CHDOWN
- PIP_CHUP
- PIP_ONOFF
- PIP_SCAN
- PIP_SIZE
- PIP_SWAP
- PLAY
- PLUS100
- PMODE
- POWER
- POWEROFF
- POWERON
- PRECH
- PROGRAM
- QUICK_REPLAY
- REC
- RED
- REPEAT
- RESERVED1
- RETURN
- REWIND
- REWIND_
- RIGHT
- RSS
- RSURF
- SCALE
- SEFFECT
- SETUP_CLOCK_TIMER
- SLEEP
- SOURCE
- SRS
- STANDARD
- STB_MODE
- STILL_PICTURE
- STOP
- SUB_TITLE
- SVIDEO1
- SVIDEO2
- SVIDEO3
- TOOLS
- TOPMENU
- TTX_MIX
- TTX_SUBFACE
- TURBO
- TV
- TV_MODE
- UP
- VCHIP
- VCR_MODE
- VOLDOWN
- VOLUP
- W_LINK
- WHEEL_LEFT
- WHEEL_RIGHT
- YELLOW
- ZOOM_IN
- ZOOM_MOVE
- ZOOM_OUT
- ZOOM1
- ZOOM2
