node-red-contrib-input-split 0.1.0
Split an input on multiple outputs based on the provided configuration.
npm install node-red-contrib-input-split
RedConnect Approved
Overview
Example
Assuming that our configuration is to split the input on :
payload.a --> output 1
payload.b --> output 2
payload.c --> output 3
The below input will become
       "payload" : {
           "a" : 2,
           "b" : 3,
           "c" : 4
       "_other" : 4
Output 1
       "payload" : 2,
       "_other" : 4
Output 2
       "payload" : 3,
       "_other" : 4
Output 3
       "payload" : 4,
       "_other" : 4
Input Split
This node defines from which point the flow splits.
The node have the following properties :
Properties to Split
Here you define how many couples of input [tiny arrow] --> outputs that you want, the value in output is always putted as payload.
Version: 0.1.0
Rating: 5.0 2
29 in the last week
  • sqlarray
  • Input Split
  • flow
  • split
  • redconnect
  • Maurizio Carboni
