node-red-contrib-ibmconnections 1.7.0
HCL Connections NodeRed nodes
npm install node-red-contrib-ibmconnections
npm-version npm-downloads
This package contains a set of nodes to interact with HCL Connections.
Changes
Changes in V1.7.0
  • The Simple Search node has been completely revised. It provides far more options to constrain the search and a more complete and precise output.
Changes in V1.6.0
  • A new Set Profiles node has been created which allows you to modify any editable attriibute (and/or tag) of any user within the same organization.
    This node requires to be associated with a LOGIN node attached to a user who has the Profile Administrator role for the organization.
    • If on premises, this means that the user attached to the LOGIN node is in the admin role for the Profile application.
    • If in cloud, this means that the user has the Administrator role for the Organization AND the organization itself has been granted the delegation flag
  • The Get Profiles node can also return, on demand:
    • the profile attributes as they are returned by the Profiles Administration API.
    • the tag Cloud of the user
Changes in V1.5.0
  • The Get Community node has been completely redesigned to return full details of the Community/ies.
    See the node help for more details.
    Note that some of the incoming input attributes may have been renamed.
  • A new Create/Update Community node has been created which allows you to either create or modify a new/existing Community (or Sub-Community). This node allows you to manage the Community Membership, as well as the list of widgets/applications that are part of the Community. It is also possible to set/update the Community Logo image.
  • The Get Profiles node has been completely redesigned to return full details of the retrieved profiles.
  • The previously mentioned nodes, Get Profile, Get Community and Create/Update Community, introduce a new Error Handling approach that makes use of the standard NodeRed Catch Node.
  • Support for Delegation (X_LCONN_RUNAS) for Cloud POST and PUT operations. This is an experimental feature. In order to enable it, you need to set a global context variable (X_CONN_RUNAS) in the following way: global.set("X_CONN_RUNAS", "node_id:user_id") where node_id is the id of the Login node which performs the delegation and user_id is the id of the user who gets delegated
Changes in V1.4.1
  • The Get Files node now returns also folders (optionally in a recursive way)
  • We added an Upload File node that enables uploading files to HCL Connections. The node supports uploading a file into the user's library and into a community's library.
  • The Get AS node has been limited to returning 20 entries by default. For this reason we added the parameter count for specifying the maximum number of returned entries.
List of nodes
This package will add the following nodes into your node-red palette :
  • The New Activity node
  • The Get Activities node
  • The Update Activity node
  • The Get Forum node
  • The Get Communities node
  • The Create/Update Communities node
  • The Get AS node
  • The Post to AS node
  • The Set Profiles node
  • The Upload File node
The Get AS node
This node retrieves the content of the Activity Stream of yourself, of someone else or of a Community. The number of returned entries from an activity stream has been limited to 20 by default. If you want to get more or less entries, you can set the Count value to an integer.
The Post to AS node
This node let you push some text (with or without an embedded experience) into the activity stream of yourself, of someone else or of a Community.
This node retrieves the complete information from the profile of an HCL Connections user.
This node updates any editable attribute and/or tag for any user within the same organization.
The Get Files node
This node retrieves the files for the current user, for another user, for a community or the public files. It is possible to retrieve files SharedWith and/or SharedBy
Uploads a file to the file library of a user or a community in HCL Connections. The incoming payload has to be a stream of buffers or a single buffer object.
This node let you create a new Activity (you can specifiy if the Activity is based on a Template and if it needs to be created inside a Community)
This node let you retrieve the information for one or more Activities based on tags or on ID
This node let you add a Section, a Bookmark or a ToDO to an existing Activity. It also allows you to move an entry from one section to another.
This node let you retrieve all the information for one (specieid by an ID) or more Communities based on tags or on a search string.
This node let you create a new Community (or Subcommunity) or modify an existing one. It supports full membership management, Community widget/application Management and setting/updating the Community Logo
This node performs a Simple Search on HCL Connections, based on flexible and customizable search criteria
LOGIN configuration node
All the nodes described above require a configuration node in order to work. This is the ICLogin node. The node supports both Basic Authentication and OAuth2.0 Authentication. The same configuration node can be reused across all the instances of the previously described nodes.
Supported environments
These nodes are intended for On-prem instances of HCL Connections >= 4.0 and also for HCL Connections Cloud
Version: 1.7.0
Updated 4 years, 4 months ago
Rating: 5.0 2
1 in the last week
  • ICLogin2
  • ICActivitiesNew
  • ICActivitiesGet
  • ICActivitiesUpdate
  • ICForumsGet
  • ICCommunitiesGet
  • ICCommunitiesUpdate
  • ICASGet
  • ICASPut
  • ICProfilesGet
  • ICProfilesSet
  • ICFilesGet
  • ICFilePut
  • ICSimpleSearch
  • ibmconnections
  • Stefano Pogliani
