node-red-contrib-ibm-wiotp-device-ops 0.1.3
A collection of Node-RED nodes that can perform a wide range of device and gateway operations on the Watson IoT platform
npm install node-red-contrib-ibm-wiotp-device-ops
A collection of Node-RED nodes to perform device and gateway operations using the Watson IoT Platform.
IBM Watson IoT Device / Device Type Operations
Install from npm
##Device Type Manager node:
Device Type Manager node can perform actions on device types in the IBM Watson IoT Platform. For some fields, the value can be passed in the msg. Any fields set on the node explicitly take precedence.
Authentication
Authentication type :
  1. Bluemix Service - Uses the Watson IoT Platform service bound to the application.
  2. API Key - Use an API key for your Watson IoT Platform organization.
Device Type
Available for delete, retrieve single device type or update operations, this specifies the Device type for the operation. May be specified by msg.payload.deviceType.
Class Id
Available for create operation. Either 'Gateway' or 'Device'.
Operations
Specifies the operation to be performed. For more information, read the Watson IoT Platform documentation. May be specified by msg.operation.xxx where xxx values supported are:
  • GetAll
    • Create
      • Delete
        • Get
          • Update
Serial Number (Optional property)
Serial Number can form one aspect of a devices identifying attributes. Serial numbers are likely to be unique within a model number, but cannot be taken as a device identifier alone. May be specified by msg.payload.serialNumber.
Device Info Description (Optional property)
This will be copied to all devices of this type when they are added to the Watson IoT Platform. May be specified by msg.payload.infoDescription.
Manufacturer (Optional property)
The attribute lists the manufacturer of devices in this device type. May be specified by msg.payload.manufacturer.
Firmware Version (Optional property)
Current firmware version installed on the device. May be specified by msg.payload.firmwareVersion.
Model (Optional property)
This denote groups of devices that serve the same function or have the same characteristics, but may have different hardware versions. May be specified bypayload as msg.payload.model.
Hardware Version of a device (Optional property)
May be specified by msg.payload.hardwareVersion.
Device Class (Optional property)
A class of devices is a grouping of devices sharing certain characteristics. A device class usually serves a descriptive function. May be specified by msg.payload.deviceClass.
Descriptive Location (Optional property)
The descriptive location of a device is a separate attribute of a device, and gives a descriptive location rather than a specific measured location. May be specified by msg.payload.descriptiveLocation.
Metadata (Optional property)
Metadata can be used to define custom attribute fields that are not provided by the Watson IoT Platform. May be specified by msg.payload.metadata.
Device manager node :
Device manager node lets you perform actions on devices that are connected to IBM Watson IoT Platform. For some fields, the value can be passed in the msg. Any fields set on the node explicitly take precedence.
Authentication
Authentication type:
  1. Bluemix Service - Use the Watson IoT service bound to the application.
    1. API Key - Use an API key for your Watson IoT Platform organization.
Device Type
The device type for the operation. May be specified by msg.payload.deviceType.
Device Operation
Operations that can be performed on the device on Watson IoT Platform. For more information, read the Watson IoT Platform documentation. May be specified by msg.operation.xxx where xxx values supported are:
  • GetAll
    • Create
      • Get
        • Update
          • Delete
            • GetLoc
              • UpdateLoc
                • GetDm
Examples
Create device using msg.payload.:
        "deviceId": "string",
        "authToken": "string",
        "deviceInfo": {
            "serialNumber": "string",
            "manufacturer": "string",
            "model": "string",
            "deviceClass": "string",
            "description": "string",
            "fwVersion": "string",
            "hwVersion": "string",
            "descriptiveLocation": "string"
        "location": {
            "longitude": 0,
            "latitude": 0,
            "elevation": 0,
            "accuracy": 0,
            "measuredDateTime": "2016-08-07T18:50:51.553Z"
        "metadata": {}
Bulk create/delete, pass the the input as an array in msg.payload:
        "typeId": "RaspberryPi",
        "deviceId": "pi01"
        "deviceId": "pi02"
Copyright 2014, 2016 IBM Corp. under the Apache 2.0 license.
Version: 0.1.3
Updated 6 years, 11 months ago
  • device-manager
  • wiotp
  • device-type-manager
  • IoT
  • Watson
  • manager
  • Device
  • Type
  • Amit M Mangalvedkar
  • Jeffrey Dare
  • Hari hara prasad Viswanathan
