node-red-contrib-hyperledger-composer 1.0.1-20170531221840
Hyperledger Composer nodes for node-red
npm install node-red-contrib-hyperledger-composer
#node-red-contrib-hyperledger-composer A set of nodes for interacting with Hyperledger Composer
Note : These node will only work if you are running node red locally. It won't work if you are using node red on bluemix.
##Hyperledger-Composer-Out A node red output node that allows you to create or update assets or participants and submit transactions.
###Example Usage This example uses the Car Auction Sample Network that can be obtained from here
The Car Auction Sample, simulates a car auction. It has two kinds of participant. An Auctioneer, who is responsible for conducting the auction, and a member who can bid on cars in the auction. In this example we will create a participant, the participant .
  1. Deploy the Car Auction Sample Network using the playground or on the command line (If you don't know how to do this go here)
  2. Create a hyperledger-composer-out node
  3. Enter the connection profile name, business network identifier, participant Id, and participant password on the hyperledger-composer-out node.
  4. Use an inject node and set it to use JSON and enter the following JSON
{"$class": "org.acme.vehicle.auction.Member",   "balance": 1234,   "email": "[email protected]",   "firstName": "Joe",   "lastName": "Blogs" }
  1. Using the playground or command line you should now be able to see the participant that has been created.
##Hyperledger-Composer-Mid A node red mid flow node that allows you to get assets or participants from a registry.
###Example Usage This example follows on from the above example. It will retrieve the participant that was created above.
  1. Create a hyperledger-composer-mid node
  2. Enter the connection profile name, business network identifier, participant Id, and participant password on the hyperledger-composer-mid node.
  3. Use an inject node and set it to use JSON and enter the following JSON
    {"modelName" : "org.acme.vehicle.auction.Member", "id" : "[email protected]"}
  1. Use a debug node to capture the output from the hyperledger-composer-mid node
##Hyperledger-Composer-In A node red input node that subscribes to events from a blockchain
Version: 1.0.1-20170531221840
Updated 3 weeks, 5 days ago
0 in the last day
11 in the last week
58 in the last month
  • hyperledger-composer-out
  • hyperledger-composer-in
  • hyperledger-composer-mid
  • blockchain
  • hyperledger
  • solutions
  • hyperledger-ci
