node-red-contrib-hyperion 0.1.2
Hyperion node for node-red
Node-RED Node to control a Hyperion server
Run the following command in the root directory of your Node-RED installation:
npm install node-red-contrib-hyperion
Set the msg.payload
according to your requested action.
Set Color
Set the color using an array of RGB values.
"color": [255, 100, 0] // [r, g, b]
Set Brightness
Set the brightness using a value from 0 to 100.
"bri": 80
Set Effect
Set an effect using the effects' name.
"effect": "Knight rider"
Clear
Clear the data and switch off the LEDs.
"clear": true
Sample flow
[{"id":"79aecb29.a73e84","type":"Hyperion","z":"f8cb4d31.7e4e2","server":"db98cd21.6a2bb","x":340,"y":80,"wires":[]},{"id":"4064f27a.ee301c","type":"inject","z":"f8cb4d31.7e4e2","name":"","topic":"","payload":"{ \"color\": [20, 20, 0], \"bri\":50 }","payloadType":"json","repeat":"","crontab":"","once":false,"x":130,"y":80,"wires":[["79aecb29.a73e84"]]},{"id":"db98cd21.6a2bb","type":"Hyperion-Server-Conf","z":"","ip":"127.0.0.1","port":"19444","name":"Home"}]
Copyright and license
This project is licensed under the MIT License - see the LICENSE file for details
