node-red-contrib-htu21d-2 0.1.0
Connect a Measurement Specialties HTU21D humidity sensor to Node-RED
npm install node-red-contrib-htu21d-2
This is an updated version of Maxwell's plugin which uses a different underlying library in order to support more recent versions of nodejs/node-red. This was tested with nodejs v6.9.4 and node-red v0.16.1. It was also expanded to include Vapor Pressure calculations.
A Node-RED node to query and receive data from Measurement Specialities HTU21D humidity and temperature sensors. These pre-calibrated sensors are interfaced using the I2C bus. The node also calculates the dew point temperature from the measured humidity and temperature.
Use npm to install this package locally in the Node-RED data directory (by default, $HOME/.node-red):
cd $HOME/.node-red
Alternatively, it can be installed globally:
npm install -g node-red-contrib-htu21d-2
The nodes will be added to the palette the next time node-RED is started.
Requirements
This node uses the htu21d-i2c npm package to access the device over an I2C bus. This is generally supported only on Linux. The bus device name (e.g. /dev/i2c-1) is configurable: only one actual sensor is allowed on each bus, but the bus can be shared with any other I2C device not using the (7-bit) address 0x40.
The output message payload holds the following properties:
humidity - relative humidity in %
temperature - temperature in ˚C or ˚F as configured
dew_point - calculated dew point in ˚C or ˚F as configured
vapor_pressure - calculated equilibrium vapor pressure in millibar
Measurements are repeated at a configurable interval: each measurement takes just over 0.1 second.
Version: 0.1.0
Updated 10 years, 5 months ago
License: BSD-2-Clause
6 in the last week
  • htu21d
  • htu21d
  • humidity
  • sensor
  • Alexander Schwantes
