node-red-contrib-http-multipart 0.3.2
A node-red node for providing multi-part form support for the standard node-red HTTP node.
npm install node-red-contrib-http-multipart
This node is a version of the Node-Red HTTP-in node that includes support for multi-part forms and files using Multer.
Use this module anywhere you would use the node-red-http-in node and would like to have file support. The module will usually be used with the POST method that contains a form with a file upload button.
$ npm install node-red-contrib-http-multipart
node-red should automatically detect the new node upon restarting of the server.
Once installed, a new http-multipart node will be available in your node-red nodes panel. Drag the node onto the flow sheet and use as you would the other http-in node. Output of the node will be a message which contains the files in a msg.req.files object.
To retrieve the file object, you can add a function node to the out port of the node that reads the msg.req.files object.
Configuration of this node is the same as the node-red-http-in node with the exception of the fields config option. fields refers to the fields in the form that will contain files.
Eg. For a form with the following field
<input type="file" name="myUploadedFile" />
the fields section of your node configuration would contain the following:
[ { "name": "myUploadedFile"} ]
The fields configuration is passed directly to the Fields option in the multer plugin, so you can use any options that would work for multer in the configuration area. ex:
  { name: 'avatar', maxCount: 1 },
  { name: 'gallery', maxCount: 8 }
Example
With HTML like the following:
<form action="/upload" method="POST">
    <input type="file" name="myFile" />
    <input type="submit />
</form>
You can upload to a node with the following configuration:
[{ "name": "myFile" }]
and access the files using the following function on the out port of the node
var fields = msg.req.fields;
msg.fields = Object.keys(fields);
var myFile = fields["myFile"][0];
msg.localFilename = myFile.path
All of the available properties of the file object can be found in the Multer documentation.
MIT
© 2016 John O'Connor
Version: 0.3.2
Updated 6 years, 8 months ago
56 in the last week
  • httpInMultipart
  • flow
  • http
  • express
  • multi-part
