node-red-contrib-hs100 1.0.2
Node red module for controlling HS100 and HS110 devices.
npm install node-red-contrib-hs100
This Node-RED node is for controlling tp-link Wi-Fi Smart Plug - Model HS100 (and HS110).
This node has only been tested with a HS100(UK). The HS100 is also available in US and EU plug versions. We expect they will work too.
This node simply wraps the excellent work here https://github.com/czjs2/hs100-api.
Change directory to your node red installation:
$ npm install node-red-contrib-hs100
Alternatively, use the Palette Manager in Node-RED.
Drag this node on to a worksheet and double click it. Enter the IP address of the plug on your network. Save and deploy.
Actuations
This node supports a number of actuations that are invoked by sending a msg.topic or msg.payload to the node's input.
Topic/Payload Description
on To turn the HS100 on.
off To turn the HS100 off.
info Get all plug info, combination of sysinfo, cloudinfo consumption, schedulenextaction
sysinfo Get general plug information.
cloudinfo Get TP-Link Cloud information.
consumption Get power consumption data
powerstate Returns true if plug is on.
schedulenextaction
schedulerules
awayrules
timerrules
time
timezone
scaninfo
model
Turn on
Turn off
Obtain power consumption data
The HS100 is a simple switch and does not support consumption. The HS110 includes the power consumption feature.
I have been told that the power consumption feature is working with the Australian version of the HS110.
I don't have an HS110 to test with though.
To obtain the power consumption, send a message to this node's input with the topic or payload set to consumption. The consumption data will be sent via this node's output in msg.payload.
Version: 1.0.2
Updated 2 years, 9 months ago
5 in the last week
  • hs100
  • tp-link
  • tplink
  • hs100
