node-red-contrib-home-assistant 0.3.2
node-red nodes to visually construct home automation with home assistant
npm install node-red-contrib-home-assistant
Various nodes to assist in setting up automation using node-red communicating with Home Assistant.
Project status
Project is going through active development and as such will probably have a few 'growing pain' bugs as well as node type, input, output and functionality changes. At this stage backwards compatibility between versions is not a main concern and a new version may mean you'll have to recreate certain nodes.
Getting Started
This assumes you have node-red already installed and working, if you need to install node-red see here
NOTE: node-red-contrib-home-assistant requires node.JS > 8.0 If you're running Node-Red in Docker you'll need to pull the -v8 image for this to work.
$ cd cd ~/.node-red
$ npm install node-red-contrib-home-assistant
# then restart node-red
If you are running Node Red inside Hass.io addon/container you can use Hass.io API Proxy address http://hassio/homeassistant as Home Assistant server address (server node Base URL). This way you don't need any real network address.
======= For flow examples checkout the flows here
Included Nodes
The installed nodes have more detailed information in the node-red info pane shown when the node is selected. Below is a quick summary
All Events
Listens for all types of events from home assistant
State Changed Event
Listens for only state_changed events from home assistant
State Trigger
Much like the State Changed Ndoe however provides some advanced functionality around common automation use cases.
Poll State
Outputs the state of an entity at regular intervals, optionally also at startup and every time the entity changes if desired
Call Service
Sends a request to home assistant for any domain and service available ( light/turn_on, input_select/select_option, etc..)
Get Current State
Fetches the last known state for any entity on input
Get History
Fetches HomeAssistant history on input
Get Template
Allows rendering of templates on input
Development
An environment with Home Assistant/Node Red can be easily spun up using docker and docker-compose along with built in VSCode debug enabled.
  1. Clone this repository: git clone https://github.com/AYapejian/node-red-contrib-home-assistant.git
  2. Install node dependencies as usual: cd node-red-contrib-home-assistant && yarn
  3. Start the docker dev environment: yarn run dev a. Note: First run will take a bit to download the images ( home-assistants image is over 1gb (yikes!) after that launch is much quicker) b. Note: Also first run load of HomeAssistant web interface seems very slow, but after first time it's also much faster
  4. The yarn run dev command will leave you with a terminal spitting out logs, ctrl+c out of this and it kills all the servers by design, just run yarn run dev again to pick back up. The following services and ports are launched in the dev script
service port mappings info
home-assistant 8123:8123, 8300:8300 exposed for local access via browser
node-red 1880:1880, 9123:9229 exposed for local access via browser, 9123 is used for debugging. Includes default flow example connected to home-assistant
Docker Tips
  1. If you run into environment issues running yarn run dev:clean should remove all docker data and get you back to a clean state
  2. All data will be discarded when the docker container is removed. You can map volumes locally to persist data. Create and copy as directed below then modify docker-compose.yaml to map the container directories to the created host dirs below. See: ./_docker/docker-compose.mapped.yaml for an example or just use that file to launch manually
mkdir -p _docker-volumes/home-assistant/config
mkdir -p _docker-volumes/node-red/data
cp _docker/home-assistant/root-fs/config/* _docker-volumes/home-assistant/config/
cp _docker/node-red/root-fs/data/*  _docker-volumes/node-red/data
Node Debugger via VSCode
Optional but it's pretty nice if you have VSCode installed.
  • Open the project directory in VSCode
  • Go to the debug tab ( or cmd/ctrl+shift+d)
  • In the debug tab you should see an target for "Attach: Docker", run that guy and you can place debug breakpoints and changes will be reloaded within docker automatically
  • Open http://localhost:8123 for HomeAssistant (password is password by default).
  • For node-red either open up via the HomeAssistant web link or left hand menu or just open a browser tab to http://localhost:1880
Other Dev Tips
  • If you're using VSCode and annoyed that node-red html ( type="x-red" ) isn't syntax highlighted you can run force it by adding support. Below is for Mac, can do the same manually on any platform however, note that this is a hack as I couldn't find any other good way to do this.
# For VSCode
sed -i .orig 's/text\/(javascript|ecmascript|babel)/text\/(javascript|ecmascript|babel|x-red)/' "/Applications/Visual Studio Code.app/Contents/Resources/app/extensions/html/syntaxes/html.json"
# For VSCode Insiders
sed -i .orig 's/text\/(javascript|ecmascript|babel)/text\/(javascript|ecmascript|babel|x-red)/' "/Applications/Visual Studio Code - Insiders.app/Contents/Resources/app/extensions/html/syntaxes/html.json"
Version: 0.3.2
Updated 6 years, 5 months ago
Rating: 3.4 7
94 in the last week
  • server
  • server-events
  • server-state-changed
  • trigger-state
  • poll-state
  • api-call-service
  • api-current-state
  • api-get-history
  • api-render-template
  • home-assistant
  • home assistant
  • home automation
