node-red-contrib-heatmiser 0.0.5
A Node-RED node to control and poll a HeatMiser thermostat.
npm install node-red-contrib-heatmiser
Input node
Expects a msg.payload with a JSON object that contains settings for the Heatmiser thermostat
msg.payload can currently be either a heating boost option, or a run mode, as below:
Heating boost
{heating: {target: TARGET_TEMPERATURE, hold: MINUTES_TO_STAY_ON_FOR}}
Run mode
{runmode:"frost"}
{runmode:"heating"}
Output node
Will read and send a status update at a configurable time interval. This is set to every 30 minutes by default.
Version: 0.0.5
Updated 8 years ago
6 in the last week
  • heatmiser-in
  • heatmiser-out
  • heatmiser
