node-red-contrib-globalcache 0.4.0
Global Cache (iTach & iTach Flex) for node-red
Description
Global Cache (iTach & iTach flex) nodes for node-red.
iTach protocol documentation: http://www.globalcache.com/files/docs/API-iTach.pdf
Install via NPM
From inside your node-red directory:
npm install node-red-contrib-globalcache
What's inside?
It includes three nodes:
globalcache-controller
: a unique CONFIG node that holds connection configuration for GlobalCache and will acts as the encapsulator for GlobalCache access. As a node-red 'config' node, it cannot be added to a graph, but it acts as a singleton object that gets created in the the background when you add an 'gc' or 'gc-device' node and configure it accordingly.globalcache-out
: GlobalCache output node that can send GlobalCache, so it can be used with function blocks.globalcache-in
: GlobalCache listener node, who emits flow messages based on activity on the GlobalCache bus. Not working in v0.2.0.
Message for GlobalCache output node contains fields:
payload
- (REQUIRED) must be JavaScript object or a string, an example:
"serial":"setstate,1:1,1"
or
setstate,1:1,1
If one specify three parameters: unit_number
, output
and command
, than all incoming string commands will be transformed into GlobalCache packet: [command],[unit_number]:[output],[command]
format
- must be equalccf
orhex
for IR Commandsjustnow
- should containtrue
for commands that shoulds be executed just now (without Queue of commands)
Right now it not tested in all directions, working with IP2CC and WF2IR.
According to official documentation: http://nodered.org/docs/getting-started/adding-nodes.html
##TODO
Implement autodiscovery by Beacon and arp tables
