node-red-contrib-get-hrefs 2.1.0
A Node-RED node to get all href urls from an HTML string
A node that extracts all <a href="">
targets from payload
in the input message and attaches them as an array hrefs
on the output message.
Install node-red-contrib-get-hrefs
using npm:
npm install --save node-red-contrib-get-hrefs
To use the node, launch Node-RED (see running Node-RED for help getting started).
The input payload should be the HTML to get hrefs from.
If the input message contains a url
property it will be used as
the baseUrl
option for get-hrefs
under the hood.
The output message will be the same as the input but with an hrefs
array containing all found href urls in the HTML body.
Icon credit
The node icon is the link-variant icon from Material Design Icons by Austin Andrews @Templarian.
MIT © Joakim Carlstein
