node-red-contrib-ftp-sftp 1.8.8
A node-red node that support FTP and SFTP file transfer using $() environment variables to control the ftp connection details
npm install node-red-contrib-ftp-sftp
http://www.HardingPoint.com
A Node-RED node to FTP and SFTP Client. This is a work in progress but does work to list and put files. Please send log issues or email requests to Support@HardingPoint.com. (https://github.com/HardingPoint/node-red-contrib-ftp-sftp)
process.env.SFTP_SSH_KEY_FILE - If you want to use private SSH key set this environment variable
SFTP & FTP
PUT - Set msg.payload.filedata to the file contents you want pushed and will be uploaded to {GUID}.FileExtension. If you need more changes file request to github.
GET - Set msg.payload.filename to get the file or will use Workdir + Filename in configuration. Leave configuration blank to set in code.
DELETE - Set msg.payload.filename to delete the file or will use Workdir + Filename in configuration. Leave configuration blank to set in code.
LIST - Uses the workdir
Sample Function Node
//      All functions above use information.
//      Sample Javascript Used In Function Node
msg.payload = {};
msg.payload.filename="./SAMPLE_FILE.txt"; // Full Path
msg.payload.filedata='{}'; // Needs to be a string
Acknowledgements
The node-red-contrib-force uses the following open source software:
See [license] (https://github.com/HardingPoint/node-red-contrib-ftp-sftp/blob/master/LICENSE) (Apache License Version 2.0).
Version: 1.8.8
Updated 6 years ago
26 in the last week
  • ftp
  • ftp in
  • sftp
  • sftp in
  • ftp
  • sftp
  • redconnect
