node-red-contrib-ftp-beta 0.0.3
A Node-RED node to FTP Server.
npm install node-red-contrib-ftp-beta
NPM
This node will allow you to LIST, GET, PUT and DELETE files on a remote FTP server. The GET and PUT options use msg.filename (the path/name of the file on the remote machine) and msg.localFilename (the path/name of the file on the local machine - i.e. the one running NR).
The DELETE option only specifies msg.filename (the path/name of the file on the remote machine) The LIST option returns an array of the file/folders in the user's default ftp folder, containing type, name, sticky, rights(an object), acl, owner, group, size and date.
Example
[{"id":"91039113.5ae0b8","type":"debug","z":"e052b363.bcca48","name":"","active":true,"console":"false","complete":"payload","x":494,"y":72,"wires":[]},{"id":"ebf6cb8.83c77b8","type":"inject","z":"e052b363.bcca48","name":"","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":114,"y":141,"wires":[["18704d55.fa8d63"]]},{"id":"18704d55.fa8d63","type":"function","z":"e052b363.bcca48","name":"","func":"msg.filename = 'test.csv';\nmsg.localFilename = '/Users/xxx/Desktop/test_remote.csv';\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":141,"wires":[["6f4f3dda.a20a7c"]]},{"id":"6f4f3dda.a20a7c","type":"ftp in","z":"e052b363.bcca48","ftp":"a7676b1a.e9714","operation":"delete","filename":"","localFilename":"","name":"","x":440,"y":143,"wires":[["be82074.47a8878"]]},{"id":"8e30f382.5971f8","type":"inject","z":"e052b363.bcca48","name":"","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":108,"y":67,"wires":[["be82074.47a8878"]]},{"id":"be82074.47a8878","type":"ftp in","z":"e052b363.bcca48","ftp":"a7676b1a.e9714","operation":"list","filename":"","localFilename":"","name":"","x":276,"y":68,"wires":[["91039113.5ae0b8"]]},{"id":"a7676b1a.e9714","type":"ftp","z":"","host":"xxx.xxx.xxx.xxx","port":"21","secureOptions":"","user":"username","connTimeout":"","pasvTimeout":"","keepalive":""}]
Acknowledgements
The node-red-contrib-force uses the following open source software:
  • [node-ftp] (https://github.com/mscdex/node-ftp): node-ftp is an FTP client module for node.js that provides an asynchronous interface for communicating with an FTP server.
See [license] (https://github.com/joeartsea/node-red-contrib-ftp/blob/master/LICENSE) (Apache License Version 2.0).
Version: 0.0.3
Updated 6 years, 8 months ago
License: Apache
3 in the last week
  • ftp
  • ftp in
  • ftp
