node-red-contrib-fs 1.4.1
Node-Red Node that handles the host filing system.
npm install node-red-contrib-fs
Node-Red nodes that work with the host filing system.
  • file-lister - List all files and/or folders from a given starting folder based on the search option chosen. File and folder names allow filtering patterns. Also has options for file details and sub-folder recursion.
  • file-copier - In progress. Simple node to copy files (optionally with wildcard specifications).
The recommended installation method is to use the Palette Manager in the Node-RED Editor.
Alternatively, run the following command in your Node-RED userDir folder.
To install a development version, use:
npm install https://github.com/TotallyInformation/node-red-contrib-fs/tarball/master
Updates
  • 0.0.9 - Initial release - File lister. 2016-06-14
  • 1.0.0 - Reworked File lister, more options. 2016-06-14
  • 1.0.1 - Fix from Andreas Brain correcting URLs in package.json. 2016-06-22
  • 1.1.0 - 2019-09-22
    • PR from juggledad (amended) adds option to exclude files/folders that start with a dot (e.g. hidden)
    • Fix from Lena Derksen fixes Issue #9 by sending new messages rather than overwriting the incoming message on every send.
    • Readiness for Node-RED v1.0
    • If root folder is empty, return an empty array or a warning payload (based suggestion from jpmalich)
    • Fixed file stat output - created was reporting incorrect date/time except on Windows. statusChanged datetime now added - see Node.js docs for details.
    • Plus other minor updates/fixes.
  • 1.1.1 - Bug fixes and tidy
    • Add GitHub templates
    • Minor tidy of main code
    • Improve NR v1 send/done functions
    • Remove spurious console.log(file)
    • Remove input _msgid from output so that all output messages get their own _msgid (Fixes Issue #11)
    • Update dependencies to latest
  • 1.2.0 - 2020-01-06 new functionality(*)
    • Folder pattern matching added
    • Search for files, folders or both added
    • all options now set able the incoming msg
    • (*) because of the new functionality, existing nodes may see more results returned
  • 1.3.1 - 2020-01-13 new functionality & bug fix
    • Fix memory leak Issue #18 - thanks to Colin for reporting.
    • Add configuration option to turn off output warnings - these can be excessive as they include "cannot access" general warnings (permissions).
    • Code tidy
  • 1.3.2 - 2020-01-15 Bug Fix
    • Fix inability to pass in start folder via msg Issue #19 - thanks to Paul for reporting.
  • 1.3.3 - 2020-08-29 Bug Fix
    • Fix override of hidden flag not working Issue #20 - thanks to Paul for reporting.
  • 1.4.1 - 2020-08-29 Additional file details added
    • Added the following flags to the stat object which is included if the "file details" flag is set:
      isBlockDevice, isCharacterDevice, isDirectory, isFIFO, isFile, isSocket, isSymbolicLink
Depends On
You need Node.JS v8.16+ and Node-RED v0.16+ to use this Node.
To Do
Please see Issue #3 on GitHub for details about where this Node will go next.
If you have other ideas for filing system related nodes, please raise an issue.
This code is Open Source under an Apache 2 License. Please see the apache2-license.txt file for details.
You may not use this code except in compliance with the License. You may obtain an original copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. Please see the License for the specific language governing permissions and limitations under the License.
Author
Julian Knight (Totally Information), https://github.com/totallyinformation
#Feedback and Support
Please report any issues or suggestions via the Github Issues list for this repository.
For more information, feedback, or community support see the Node-Red Google groups forum at https://groups.google.com/forum/#!forum/node-red
Version: 1.4.1
Rating: 5.0 5
370 in the last week
  • fs
  • files
  • folders
  • Andreas Brain
  • juggledad
  • Lena Derksen
  • jpmalich
