node-red-contrib-freeboard 0.0.7
Freeboard Dashboard Node for Node-RED
npm install node-red-contrib-freeboard
#Freeboard Dashboard for Node-RED
#Installation Just install this plugin to your Node Red installation by using npm: "npm install node-red-contrib-freeboard" in your Node Red root directory
#Usage Drag the freeboard node into your workspace and connect it appropriatley with some JSON emitting node. Node RED Flow
[{"id":"176e3fcd.e891c","type":"freeboard","name":"[Node-RED] Freeboard","x":715,"y":233,"z":"681a559a.97e5ac","wires":[]},{"id":"41e8ab5f.be1754","type":"inject","name":"Send Random Value","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":268,"y":233,"z":"681a559a.97e5ac","wires":[["c822ddf4.37dd2"]]},{"id":"c822ddf4.37dd2","type":"function","name":"","func":"msg.payload={value:Math.floor(Math.random()*100)};\nreturn msg;","outputs":1,"x":502,"y":233,"z":"681a559a.97e5ac","wires":[["176e3fcd.e891c"]]}]
Then go to your freeboard dashboard (is bundled with this node - no need to set up something; should run under /freeboard) and add the freeboard node from Node-RED as Datasource Click "ADD" below "DATASOURCE" Add Datasource
Choose the Type that has the Name of your Node-RED node (in this case "[Node-RED] Freeboard") and give it a name that you want it to be available under in Freeboard. Save Datasource
Now you can add a Widget using the Datasource: Click on "ADD PANE" on the top left and in the new created pane on the "+" sign in the title Create Widget Choose the appropriate datasource. If Freeboard already received data from your node it will also offer you available properties - so best would be to hit the inject node within Node-RED at least once.
Thats it, here is your widget:
Widget
Don't forget to save your dashboard by hitting "SAVE FREEBOARD" (then "[MINIFIED]") on the top left.
#Contributions Thanks to reyiyo and adamfr33man for their contributions to this project!
Version: 0.0.7
Updated 11 years, 3 months ago
13 in the last week
  • freeboard
  • freeboard
  • dashboard
