node-red-contrib-fplug-splitter 1.0.2
NodeRED node to split flow from FPlug logger.
npm install node-red-contrib-fplug-splitter
A NodeRED node of splitting FPlug log made by fplug-logger.
It assumes the payload of an input message consists of
  "time": "UNIX time when the log received.",
  "illuminance": "Integer value of logged illuminance",
  "temperature": "Integer value of logged temperature",
  "power": "Integer value of logged power",
  "humidity": "Integer value of logged humidity"
It outputs four messages;
  1. illuminance
  2. temperature
  3. power
  4. humidity.
Each payload consists of
  "value": "Observed value",
and the topic of the message will be set as same as original topic with type postfix, such as -illuminance, -temperature, -power, or -humidity.
Run the following command in the root directory of your Node-RED install.
$ npm install node-red-contrib-fplug-splitter
This software is released under the GNU General Public License version 3, see LICENSE.
Version: 1.0.2
Updated 1 year, 1 month ago
License: GPL-3.0
8 in the last day
19 in the last week
58 in the last month
  • fplug-splitter
  • jkawamoto
