node-red-contrib-fluentd-parser 1.1.0
NodeRED node for parsing logs from Fluentd.
A Node-RED node to parse logs posted from Fluentd.
A payload of a message posted from Fluentd consists of log property. This node replaces payload property as the log property so that other nodes easily access to the log data.
If the log property is a JSON string, this node decodes it to an object.
If the message is originally from a docker container, the payload of the message has container_name property. This node sets the container_name as the topic of the message.
Run the following command in the root directory of your Node-RED install.
$ npm install node-red-contrib-fluentd-parser
This software is released under the GNU General Public License version 3, see LICENSE.
