node-red-contrib-flow-combine 0.1.1
Combine multiple flows into one waiting until a number (static or dynamic) of iterations are made.
npm install node-red-contrib-flow-combine
Overview
Combine Start
This node defines from which point the flow splits.
The node have the following properties :
Wait an Array
If this property is checked, then the number of iterations which Combine End waits is the length of the Array.
Iterate over the Array
Split the Array on multiple messages.
Number of flows
If the other property is unchecked then the node Combine End will wait the number written in this property.
Combine End
This node doesn't produce any Output until all the expected iterations are done.
Output processed data
If this property is checked, then the node collects in an Array, data from each iteration and at the end provides that in the payload. If on the start node is enabled Iterate over the Array the elements of the result Array have the same order as in the input Array.
