node-red-contrib-float 1.0.3
Node-RED node to parse decimal and binary numbers to IEEE-754 Floating Point Numbers
npm install node-red-contrib-float
Buy Me A Coffee
Node Red node to convert binary and decimal numbers in IEEE-754 floating point numbers
Input msg.payload can be a Number or a binary String (just '0' and '1' chars) or an Array of this two objects. Output msg.payload will be a Float or an Array of Float.
It's possible to set the max number of decimal digit of the output float Number with the node 'Decimal Digits' property. If left blank the number will not be truncated.
Version: 1.0.3
Updated 4 years, 11 months ago
Rating: 4.0 3
88 in the last week
  • toFloat
  • IEEE-754
  • robertsLando
  • Float32
  • Float
  • Converter
  • Decode
