node-red-contrib-flic-buttons 2.0.0
A Node-RED node to inject events from flic buttons
npm install node-red-contrib-flic-buttons
A Node-RED node to interact with the flic.io BLE buttons. Originally created by hardilib, this is actually a fork from osos's version, which added an option for auto-disconnect timeout to save battery life in the Flic buttons.
This fork includes two major upgrades:
  • Auto-reconnect to the server. If your flicd server restarts, the node will reconnect and reattach all connection channels, without missing a beat.
  • Multiple events can be triggered from one node.
See change log for full details.
Installing Flic Daemon
This node requires the fliclib-linux-hci daemon to handle the low level comunication with the buttons. You will need to install this before you start:
git clone https://github.com/50ButtonsEach/fliclib-linux-hci.git
you can either start the daemon manually:
cd bin/armv6l/
sudo ./flicd -f flic.sqlite3
or you can edit /etc/rc.local to start the daemon on boot:
sudo nano /etc/rc.local
Add the following line just before the exit 0:
sleep 10 &&  /home/pi/git/fliclib-linux-hci/bin/armv6l/./flicd -d -l /var/log/flic.log  -f /home/pi/git/fliclib-linux-hci/bin/armv6l/flic.sqlite3 &
(obviously change the paths to match where you have installed)
Pairing Buttons
Buttons need to be paired before you can use this node at the moment. We do this using the scanwizard.js located in the lib folder.
  • Ensure that the daemon are running
  • Ensure that any phones or other devices that your flic buttons were previously paired with are switched off or have bluetooth disabled
  • navigate to node-red-contrib-flic-buttons/lib
  • type the command node scanwizard.js
  • press your flic button
  • If it has previously been paired to another device you will have to hold the flic button down for 7 seconds to put it into public mode
  • once paired take a note of the bluetooth address
  • repeat this for all your flic button noting down the address for each button
Adding Buttons to Node-Red
Each flic node requires you specify a button and at least one click type. The button is configured with a configuration node that can be shared amounst multiple flic nodes.
The button config node takes the following parameters:
  • Host - this is the host running the flic.io daemon process, defaults to localhost
  • Port - the port for the daemon process, defaults to 5551
  • Button Address - the bluetooth address that you noted down when pairing your buttons
The node emits a msg.payload that looks like this
  "deviceId":"80:E4:DA:70:XX:XX",
  "queued":true,
  "timeDiff":0,
  "clickType":"ButtonDown"
ClickType can be:
  • ButtonDown - triggered as soon as the button is pressed, regardless of single, double, or hold. (Note: will trigger twice during a double click operation)
  • ButtonUp - triggered as soon as the button is released, regardless of single, double, or hold. (Note: will trigger twice during a double click operation)
  • ButtonClick - triggered after the button is released and was held for at most 1 second
  • ButtonSingleClick - triggered after the button is clicked once
  • ButtonDoubleClick - triggered after the button is clicked twice (time between clicks is at most 0.5 seconds)
  • ButtonHold - triggered immediately once the button is held for at least 1 second
Version: 2.0.0
Updated 5 months, 3 weeks ago
Rating: 3.7 3
15 in the last week
  • flic
  • Flic Button
  • Flic Server
  • flic.io
  • ble
  • Giles Roadnight
  • Justin Halbsgut
