node-red-contrib-exosite 0.3.3
A node for node-red that uses the device api to talk to Exosite's Murano
npm install node-red-contrib-exosite
A node-red node that accesses devices on Exosite's Murano platform.
It uses the HTTP Data API to read, write, or watch aliases on a device.
Device config
The exosite nodes are configured to talk to a device instance inside Murano. This instance has a set of aliases that descibe the points where data can be read or wrote. Each device instance is defined by a product ID and serial number.
If node-red is running on a machine that also has Gateway Engine (GWE) installed, you can select 'GWE' to access the Gateway Engine's device instance.
A device instance in Murano needs to be in the 'notactivated' or 'whitelisted' state so that it can be activated by the exosite node-red node. This happens when you create a new device in Murano.
Version: 0.3.3
Updated 9 years, 7 months ago
License: BSD-3-Clause
4 in the last week
  • exo-config-client
  • exo-write-client
  • exo-read-client
  • exo-watch-client
  • exosite
  • oneplatform
  • murano
