node-red-contrib-evrythng 0.1.1
Node-RED module to access the EVRYTHNG API.
npm install node-red-contrib-evrythng
EVRYTHNG Node-RED
A simple Node-RED node that performs read or write requests on a Property of a Thng with the EVRYTHNG IoT Platform (free developers accounts!).
To install the module, you can either install it locally within your node-RED user data directory (by default, $HOME/.node-red):
cd $HOME/.node-red
npm install npm install node-red-contrib-evrythng
or globally alongside Node-RED:
sudo npm install -g node-red-contrib-evrythng
You can send a payload to the node including Thng, key and value to update the Property of an existing Thng:
  "key" : "temperature",
  "value" : 10
  "thng" : "76a267a7e4c3a4cfcca9b9ac"
Alternatively, you can set the Thng, key and value in the node configuration The node sends a message to: https://api.evrythng.com/thngs/<msg.payload.thng>/properties And the payload that is sent ends up in the format:
  "key" : <code>msg.payload.key</code>,
  "value" : <code>msg.payload.value</code>
Version: 0.1.1
Updated 9 years, 2 months ago
3 in the last week
  • evrythng
  • evrythng
