node-red-contrib-envisalink 1.1.5
DSC alarm system support for node-red using the EnvisaLink module
npm install node-red-contrib-envisalink
Node-RED Modbus License Standard - JavaScript Style Guide NPM version
DSC alarm systems integration with Node-RED using the EnvisaLink hardware.
This node allows you to listen to state changes in your DSC alarm as well as sending commands such as arming and disarming of your alarm.
Run the following command for global install
npm install -g node-red-contrib-envisalink
How to use
The output node, with which you send commands, takes a raw TPI command as a string. Please refer to the TPI documentation for a full list of commands. For example, to arm partition 1 using the code 9999 you would use the command 033 and passing 1 as partition and your code. The final string to pass in to the output node would be 03319999.
Flow Example
Authors
Patrik Ã…kerfeldt
History
Version: 1.1.5
Updated 6 years, 2 months ago
5 in the last week
  • envisalink-controller
  • envisalink in
  • envisalink out
  • dsc
  • alarm
  • envisalink
