node-red-contrib-elasticsearch2 0.1.12
Writes a message to elasticsearch based on a fork from benediktarnold/node-red-contrib-elasticsearch
!!! Not stable YET !!!
!!! use it at your own risk !!!
##node-red-contrib-elasticsearch2 A node-red node to write messages to elasticsearch (based on a modified fork from benediktarnold/node-red-contrib-elasticsearch with more options)
##Install Run the following command in the root directory of your Node-RED install
npm install node-red-contrib-elasticsearch2
##Documentation Inputs : msg msg.es_index will override the configured index in the node msg.es_documentype will override the configured document type in the node daily index option allows to create an index on daily basis (index <= indexYYYYMMDD if msg.es_index was not defined ) Outputs : none ##TODO - Add ouputs with error if any, newly created doc id, status of ES after operation ... etc
