node-red-contrib-elasticsearch 0.1.4
Writes a message to elasticsearch
npm install node-red-contrib-elasticsearch
Build Status
#node-red-contrib-elasticsearch A node-red node to write messages to elasticsearch
##Install Run the following command in the root directory of your Node-RED install
##Documentation Inputs : msg Outputs : none ES result : document will be created with msg fields ##TODO - add an input for index name - add an input for document type - and an ouput with error if any, doc id, status of ES after operation ... etc
Version: 0.1.4
Updated 9 years, 4 months ago
8 in the last week
  • elasticsearch
  • elasticsearch
