node-red-contrib-eibd 0.0.5
KNX for node-red through eibd, the open source KNX/EIB daemon
npm install node-red-contrib-eibd
DEPRECATION NOTICE This project is deprecated as of October 2016. Please point your browser to https://bitbucket.org/ekarak/node-red-contrib-knxjs instead. As such, not much effort is going to be spent here; my limited time will focus on the new KNX access library for Node that I've written Don't get me wrong, eibd is a wonderfully stable piece of software; its just that its scope is limited to experimental environments with a full-blown UNIX box connected to the bus, which is not your average use case. What I'm insterested instead are low-power Javascript microcontrollers like the Espruino and the Tessel 2
KNX/eibd nodes for node-red. Uses the eibd binding for Node.JS (https://github.com/andreek/node-eibd). It will include:
'eibd-controller' : a unique CONFIG node that holds connection configuration for eibd and will acts as the encapsulator for KNX access. As a node-red 'config' node, it cannot be added to a graph, but it acts as a singleton object that gets created in the the background when you add an 'eibd' or 'eibd-device' node and configure it accordingly.
-- 'eibd-out' : KNX/EIB output node that can send KNX to arbitrary GA's and datatypes, so it can be used with function blocks.
-- 'eibd-in': KNX/EIB listener node, who emits flow messages based on activity on the KNX bus:
Both use the same message format, an example message follows:
{ "topic": "knx: write", "payload": { "srcphy": "1.1.100", "dstgad": "5/0/2", "dpt": "DPT1", "value": 0 } }
-- topic is: *"knx: (telegram type)" where (telegram type) is 'read' (read requests), 'response' (to read requests) and 'write' (to update GA's)
-- payload contains:
--- srcphy: source physical address (the device that sent the KNX/EIB telegram) - this information is only emitted by eibd-in, and will be ignored by eibd-out (no address spoofing, you naughty haxx0r!)
--- dstgad: destination group address (the function that this telegram refers to eg. front porch lights) - REQUIRED
--- dpt: datapoint type (1 for booleans, 5 for 4-bit dimming setpoints etc) - defaults to 1 for boolean on/off GA's
--- value: the destination group address's value conveyed in the telegram - REQUIRED
Version: 0.0.5
Updated 10 years, 9 months ago
4 in the last week
  • eibd-controller
  • eibd-out
  • eibd-in
