node-red-contrib-edgex-connector 0.0.2
A Node-RED node to access device data from EdgeX
Node-Red connector for EdgeX
This node-red node allows you to connect Node-RED flows to EdgeX Foundry devices and services (https://github.com/edgexfoundry). It supports reading, writing, and subscribing to device resources using secure credentials from EdgeX Vault. Both Secured and unsecured mode is supported. This node can be useful for integrating EdgeX data into Node-RED flows, enabling custom computation, creating pipelines/workflows, automation, dashboard creation etc.
You can search and install node-red-contrib-edgex-connector using node-red palette
Otherwise if node-red docker is used then
docker exec -it <node-red container> npm install node-red-contrib-edgex-connector
If node-red is installed locally then do the following:
Then restart Node-RED. The EdgeX node will appear in the Node-RED palette.
How Input, Read, and Subscribe Modes Work
- Read Mode: When set to Read, the node will fetch data from the selected device resources. You can select multiple sources, and each output port will correspond to a selected resource. If a device command is selected then all the resources inside the command will have a corresponding output. The output label for each port will show the resource name. The node can be activated by an inject node.
- Subscribe Mode: In Subscribe mode, the node listens for events from the selected device resources via the EdgeX message bus (MQTT). If a device command is selected then all the resources inside the command will have a corresponding output. The output label for each port will show the resource name. The node can be activated by an inject node.
- Write Mode:
In Write mode, only one source can be selected. The input port will display the resource name. The node expects
msg.payloadto be a JSON object with resource names as keys and values to write.
Write Operation: Input Format
Input Format: For Write mode,
msg.payloadshould be a JSON object where each key is a resourceName as defined in your device profile, and the value is the value to write.Example:
msg.payload = { "AHU-TargetTemperature": "28.5", "AHU-TargetBand": "4.0", }
See the EdgeX Core Command API documentation for more details.
- Output: The output for Write mode contains only the result of the operation (the response from EdgeX Core Command), typically indicating success or failure.
Sample Docker Compose Service
The node is only tested in Dockerized environments with EdgeX Foundry. To run the EdgeX service, follow the instructions in https://github.com/edgexfoundry/edgex-compose.
Below is a sample docker-compose service definition for Node-RED with EdgeX integration:
node-red:
image: nodered/node-red
environment:
TZ: Europe/Amsterdam
EDGEX_SECURITY_SECRET_STORE: "true"
SECRETSTORE_HOST: edgex-secret-store
SERVICE_HOST: node-red
CORE_COMMAND_HOST: edgex-core-command
CORE_METADATA_HOST: edgex-core-metadata
MESSAGEBUS_HOST: edgex-mqtt-broker
MESSAGEBUS_PORT: "1883"
ports:
- "1880:1880"
user: '1000:2001'
networks:
edgex-network: null
volumes:
- node-red-data:/data
- /tmp/edgex/secrets/node-red:/tmp/edgex/secrets/node-red:ro,z
Required Environment Variables
Mandatory: SERVICE_HOST, CORE_COMMAND_HOST, CORE_METADATA_HOST, MESSAGEBUS_HOST, and MESSAGEBUS_PORT must be set. If not set, the node will default to localhost, which will not work in Dockerized EdgeX deployments.
SERVICE_HOST and the secret volume path must use the same value (e.g., node-red).
In secured mode (EDGEX_SECURITY_SECRET_STORE set to true), the node will automatically fetch the secret token from EdgeX Vault. The env SECRETSTORESETUP_HOST is also Mandatory. The secret token is stored in /tmp/edgex/secrets//secrets-token.json and is mounted read-only. Please refer https://docs.edgexfoundry.org/4.1/security/Ch-Configuring-Add-On-Services/#:~:text=simpler%20form%20of-,EDGEX_ADD_KNOWN_SECRETS,-environment%20variable's%20value to configure your node-red.
Secret Volume Configuration
The secret token must be mounted read-only from /tmp/edgex/secrets/node-red as shown in the compose file above.
'node-red' is the service name which must match the value of SERVICE_HOST.
Security Note
This node introduces a custom endpoint for retrieving device resource information, which is currently not secured. To mitigate this, it is recommended to enable global security for your Node-RED instance. See the Node-RED Security Documentation for guidance. Node-level security could also be implemented using a dedicated configuration node; however, this functionality is not yet available.
When EdgeX is running in secured mode, the tokens in /tmp/edgex/ are, by default, accessible only to the edgex user for security reasons. Running Node-RED as the edgex user may lead to permission issues with Node-RED files.
A recommended workaround is to grant read access to the EdgeX group (GID 2001) for the Node-RED token. This requires root privileges. Execute the following commands:
sudo chmod 750 /tmp/edgex/secrets/node-red/
sudo chmod 640 /tmp/edgex/secrets/node-red/secrets-token.json
Additionally, in your Docker Compose or Docker run configuration, set the user as '1000:2001'.
In the future, a configuration node may be provided to allow token retrieval directly from the UI.
This node has been tested only with Dockerized deployments of Node-RED and EdgeX.
Demo (new version contains improved UI and messages)
This project is licensed under the Apache License 2.0 - see the LICENSE file for details.
