node-red-contrib-edge-trigger 1.0.1
A set of nodes to trigger on rising or falling values
A set of nodes that trigger on edges:
rising edge
: Triggers on rising edge compared to a threshold valuefalling edge
: Triggers on falling edge compared to a threshold valuehysteresis
: Triggers on both edges compared to two threshold values building a hysteresis band
Fig. 1: Node appearance
In Node-RED (preferred)
- Via Manage Palette -> Search for "node-red-contrib-edge-trigger"
In a shell
- go to the Node-RED installation folder, e.g.:
~/.node-red
- run
npm install node-red-contrib-edge-trigger
Node Configuration
Fig. 2: Node properties (example hysteresis node)
Node configuration is quite simple: In the case of the rising edge
resp. falling edge
node, you only have to set one threshold value, in case of the hysteresis
node, you have to set two threshold values and the initial behaviour (None, Rising, Falling, Any).
Input
Input data are numerical values which are compared against threshold values. Any other input data types (e.g. string data types) are ignored (see examples: String "12 Monkeys").
Output
The nodes compare the numerical value of the incoming msg.payload
to the value of the previous message. If that value has crossed a specified threshold (given in the node configuration) in a specified direction (rising, falling), the message is forwarded to the nodes output.
Rising edge
Given a threshold value, the node rising edge
will forward its incoming msg
if the numerical value of its msg.payload
has increased above the threshold. An example applications is switching on a cooler when a temperature value rises.
Fig. 3: rising edge
incoming and outgoing messages
Falling edge
Given a threshold value, the node falling edge
has dropped below the threshold. An example applications is switching on a heater when a temperature value drops.
Fig. 4: falling edge
Hysteresis
The node hysteresis
combines the functions of the falling edge
and rising edge
nodes. It has both rising and falling thresholds, and forwards the incoming msg
if its numerical value of its msg.payload
crosses either threshold in the appropriate direction. The outgoing message has its edge
property set to rising
or falling
(see example 2 below for the edge property).
The difference between the two threshold values is called hysteresis band.
Fig. 5: hysteresis
The hysteresis
node is useful in situations where it would not be desirable to toggle an output repeatedly on and off if a value hovers around a single threshold (e.g. caused by noise). For example, a light that is activated by a luminosity sensor: It may be appropriate to turn the light on when the sensor indicates less than 30 lux, but not to turn it off again until the sensor indicates more than 40 lux.
Examples
Remark: Example flows are present in the examples subdirectory. In Node-RED they can be imported via the import function and then selecting Examples in the vertical tab menue.
Example 1: Rising and falling edge nodes
This example shows the behaviour of the rising edge
and falling edge
nodes. You can click on the inject nodes to see which values are forwarded and displayed at the debug nodes crossing the different threshold levels.
Fig. 6: rising edge
and falling edge
example
[{"id":"aaa7c9a9.503a78","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":180,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"f3592261.3ae32","type":"rising-edge","z":"38d130a0.78811","name":"rising, threshold = 42","threshold":"42","x":530,"y":180,"wires":[["cce1f276.6a31e8"]]},{"id":"7a546816.767b3","type":"falling-edge","z":"38d130a0.78811","name":"falling, threshold = 2.7183","threshold":"2.7183","x":550,"y":260,"wires":[["db277fe1.16bd08"]]},{"id":"18ce530e.6cf78d","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"6.023e23","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":300,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"dc0d676f.c3f468","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"-3.14159","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":100,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"a55450a8.4436d","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"9.81","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":220,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"5fca1810.25af88","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"360","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":260,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"d43d7bf4.8d68","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"1.602e-19","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":140,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"369bc84.86b3ab8","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"12 Monkeys","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":360,"wires":[["f3592261.3ae32","7a546816.767b3"]]},{"id":"cce1f276.6a31e8","type":"debug","z":"38d130a0.78811","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":840,"y":180,"wires":[]},{"id":"db277fe1.16bd08","type":"debug","z":"38d130a0.78811","name":"","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":840,"y":260,"wires":[]},{"id":"f9f5884.e631978","type":"comment","z":"38d130a0.78811","name":"A string leads to no change","info":"","x":270,"y":400,"wires":[]}]
Example 2: Hysteresis node
This example shows the behaviour of the hysteresis
node.
The example flow looks like this:
Fig. 7: hysteresis
node example
[{"id":"5845ed17.5d48cc","type":"hysteresis","z":"38d130a0.78811","name":"hysteresis, 6371, 40074","rising_threshold":"40074","falling_threshold":"6371","initial_edge":"","x":540,"y":680,"wires":[["8da8954f.ea0048"]]},{"id":"739452a2.d7049c","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"384400","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":760,"wires":[["5845ed17.5d48cc"]]},{"id":"a9a751c.66373b","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"2.54","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":640,"wires":[["5845ed17.5d48cc"]]},{"id":"43cf5f4c.7f0b88","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"30.48","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":680,"wires":[["5845ed17.5d48cc"]]},{"id":"75687242.c02a5c","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"-11034","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":600,"wires":[["5845ed17.5d48cc"]]},{"id":"7b62e0da.5a45b8","type":"inject","z":"38d130a0.78811","name":"","topic":"","payload":"8848","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":720,"wires":[["5845ed17.5d48cc"]]},{"id":"8da8954f.ea0048","type":"debug","z":"38d130a0.78811","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":840,"y":680,"wires":[]}]
Example 2 node configuration
The two hysteresis values are 6371 and 40074. The node configuration is shown in the following figure.
Fig. 8: hysteresis
example node configuration
Example 2 property msg.edge
output
An output of the nodes msg.edge
property is shown in the following figure. When going below the lower hysteresis value (6371 in this example), the output shows:
Fig. 9: hysteresis
node msg.edge
property
