node-red-contrib-dynamorse-ffmpeg 0.1.2
Dynamorse processing nodes using FFmpeg for Node-RED
npm install node-red-contrib-dynamorse-ffmpeg
CircleCI
A set of nodes for IBM's Node-RED that support media processing using FFmpeg. This package is a component of Streampunk Media's dynamorse suite.
First follow the installation instructions for dynamorse-core.
This package can be installed from the 'manage palette' option in the Node-RED menu. Alternatively in your Node-RED user directory, typically ~/.node-red, run
Status, support and further development
Contributions can be made via pull requests and will be considered by the author on their merits. Enhancement requests and bug reports should be raised as github issues. For support, please contact Streampunk Media.
This software is released under the Apache 2.0 license. Copyright 2017 Streampunk Media Ltd.
Via a dependency on codecadaon, this software uses libraries from the FFmpeg project under the LGPLv3. See the codecadon licenses folder for more information.
If you use an open-source codec implementation in association with dynamorse for commercial purposes, you may or may not be infringing a patent. Streampunk Media Ltd offers no opinion on this and accepts no liability for the actions of those who use this software and subsequently infringe a patent. You are advised to speak to the patent owners or patent pool managers for the codecs you intend to use and obtain any appropriate licenses.
Version: 0.1.2
Updated 1 month ago
0 in the last day
34 in the last week
82 in the last month
  • encoder
  • AAC encoder
  • decoder
  • converter
  • packer
  • multiviewer
  • multiview setup
  • streampunk
