node-red-contrib-docloud-api 0.0.5
node-red-contrib-docloud-api =====================
Node-RED nodes to integrate optimization service into your application.
Pre-requisite
To run this you need a subscription on IBM Decision Optimization on Cloud. For details see IBM Decision Optimization on Cloud.
IBM Decision Optimization on Cloud or DOcloud for short is a service that lets you solve CPLEX and OPL problems on the Cloud. You can access the interactive service called DropSolve or you can use the API to integrate the service into your application. This module provides a wrapper over the REST API.
Run the following command in the root directory of your Node-RED install.
npm install node-red-contrib-docloud-api
Access IBM Decision Optimization on Cloud service.
docloud config
You can find your base URL and API key from Developer -> Get your API Key & base URL link
- url property: the base URL
- key property: your API Key,
'docloud default config' node
You can define a configuaration for each docloud node. If you don't specify a special configuartion for your docloud node, the default one will be used, which is defined in the 'docloud default config' node.
'docloud' node
You can do 3 operations:
- execute
- create
- submit
Check info panel in Node-RED admin console for detailed documents
This nodes emits following events:
- CREATED
- PROCESSED
- INTERRUPTED
- FAILED
- ERROR
You can use 'docloud event' node to catch them.
'docloud job' node
You can do following operations:
- list jobs
- delete jobs
- get job
- delete job
- abort job
- get job execution status
- upload attachment
- download attachment
- get log items
- download log
