node-red-contrib-db2 0.0.2
A Node-RED node to use a IBM DB2 database
npm install node-red-contrib-db2
A Node-RED node to read and write to a DB2 database.
Allows basic access to a DB2 database.
The msg.database must hold the database
The msg.topic must hold the query
and the result is returned in msg.payload.
Each row will send a new payload, so you can work with big results.
Typically the returned payload will be an array of the result rows.
If nothing is found for the key then null is returned.
Version: 0.0.2
Updated 6 years, 8 months ago
11 in the last week
  • IbmDBdatabase
  • ibmdb
  • db2
  • ibmdb
