node-red-contrib-datakitjs 0.2.1
A node-red node to perform simple data analysis on a flow.
npm install node-red-contrib-datakitjs
Node Red datakit
Data analysis tools for payload input data. This is a wrapper around the datakitjs Node library.
Inputs
Normally, the value of msg.payload is saved into the data set. When a message with a topic that ends in a datakit function name is received, that datakitjs is calculated and output as the msg.payload. For example, a message with the topic data/mean would output the mean of the data received so far. Optionally, the function name can be stripped from the topic. For datakitjs functions that require a parameter, the parameter is passed in using msg.payload.
Functions
The functions in the datakitjs library that are supported are:
Statistical Methods
  • mean
  • sd
  • vari
  • cov
  • reg
Convenience Methods
  • seq
  • rep
  • isclose
  • sum
  • prod
  • min
  • max
Random Numbers
  • exp
  • norm
  • uni
In addition, two other functions are implemented:
  • size - returns the size of the data set
  • clear - clears the data set
For more detailed information about the functions see the datakitjs API documentation.
Version: 0.2.1
Updated 9 years, 7 months ago
11 in the last week
  • datakit
  • datakitjs
