node-red-contrib-counter 0.1.6
A Node-RED node to create a counter with messages.
npm install node-red-contrib-counter
GitHub version NPM version Dependencies Status
Table of Contents
Run the following command in your Node-RED user directory - typically ~/.node-red:
By default the counter will be incremented for every inbound message and append the current count to msg.count.
  • Initial Count: The initial count can be set in the configuration. By default it will be zero at start.
  • Default Step: Default amount that will be incremented or decremented on every incoming message.
  • Lower Limit: Optional limitation of the lower count limit. Will add countLowerLimitReached to msg if reached.
  • Upper Limit: Optional limitation of the upper count limit. Will add countUpperLimitReached to msg if reached.
  • Mode: Determine if count value should be incremented or decremented on every incoming message.
  • Outputs: Selects the output format of the counter. For more info read below.
Output
There are two output options for the counter value:
  • single: The actual count will be appended to msg.count of the original msg.
  • split: The node will become two outputs, first will return the count as msg.payload and possible limitation info, the second returns the untouched original msg.
Control
It's possible to control the counter with incoming msg properties:
  • msg.increment: counter will be incremented by the given value.
  • msg.decrement: counter will be decremented by the given value.
  • msg.reset: resets the counter to it's initial count, or to the given value, when it's a number.
Example Flows
Simple example showing how to use the counter and it's output.
[{"id":"25b6280d.1ecf6","type":"inject","z":"327d23e5.bb5924","name":"decrement","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":380,"y":160,"wires":[["8a41c1.6006b64"]]},{"id":"285e0e19.b9680a","type":"inject","z":"327d23e5.bb5924","name":"increment","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":380,"y":120,"wires":[["ce8d952f.18666"]]},{"id":"fda0a334.bc9588","type":"inject","z":"327d23e5.bb5924","name":"reset","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":370,"y":200,"wires":[["17cce981.975686"]]},{"id":"ce8d952f.18666","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.increment = 2;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":120,"wires":[["ac65bf94.6e609"]]},{"id":"17cce981.975686","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.reset = true;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":200,"wires":[["ac65bf94.6e609"]]},{"id":"8a41c1.6006b64","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.decrement = 1;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":160,"wires":[["ac65bf94.6e609"]]},{"id":"ac65bf94.6e609","type":"counter","z":"327d23e5.bb5924","name":"","init":"0","step":1,"lower":null,"upper":null,"mode":"increment","outputs":"1","x":740,"y":140,"wires":[["988afc3c.a08f98"]]},{"id":"370626a8.22216a","type":"inject","z":"327d23e5.bb5924","name":"normal msg without control parameter","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":470,"y":80,"wires":[["ac65bf94.6e609"]]},{"id":"988afc3c.a08f98","type":"debug","z":"327d23e5.bb5924","name":"message","active":true,"console":"false","complete":"true","x":900,"y":140,"wires":[]}]
[{"id":"4f41c5a1.85426c","type":"inject","z":"327d23e5.bb5924","name":"decrement","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":380,"y":380,"wires":[["e9085587.2d19c"]]},{"id":"afb267a8.63739","type":"inject","z":"327d23e5.bb5924","name":"increment","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":380,"y":340,"wires":[["4a35e3c7.3dbd0c"]]},{"id":"f066adf1.21ba","type":"inject","z":"327d23e5.bb5924","name":"reset","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":370,"y":420,"wires":[["523f8e05.d5537"]]},{"id":"4a35e3c7.3dbd0c","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.increment = 3;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":340,"wires":[["f33ad4bd.777a5"]]},{"id":"523f8e05.d5537","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.reset = 10;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":420,"wires":[["f33ad4bd.777a5"]]},{"id":"e9085587.2d19c","type":"function","z":"327d23e5.bb5924","name":"msg object","func":"msg.decrement = 1;\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":380,"wires":[["f33ad4bd.777a5"]]},{"id":"9b40b088.73732","type":"debug","z":"327d23e5.bb5924","name":"count","active":true,"console":"false","complete":"payload","x":890,"y":340,"wires":[]},{"id":"f33ad4bd.777a5","type":"counter","z":"327d23e5.bb5924","name":"","init":"100","step":"1","lower":null,"upper":null,"mode":"increment","outputs":"2","x":740,"y":360,"wires":[["9b40b088.73732"],["876cc69d.d4b438"]]},{"id":"99b73d63.9fdb","type":"inject","z":"327d23e5.bb5924","name":"normal msg without control parameter","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":470,"y":300,"wires":[["f33ad4bd.777a5"]]},{"id":"876cc69d.d4b438","type":"debug","z":"327d23e5.bb5924","name":"message","active":false,"console":"false","complete":"true","x":900,"y":380,"wires":[]}]
Bugs / Feature request
Please report bugs and feel free to ask for new features directly on GitHub.
This project is licensed under Apache 2.0 license.
Donation
You like to support me?
You appreciate my work?
You use it in commercial projects?
Feel free to make a little donation! :wink:
Version: 0.1.6
Updated 6 years, 4 months ago
Rating: 3.3 6
434 in the last week
  • counter
  • counter
  • count
